BMW X5
      10-07-2020, 07:50 PM   #1
sygazelle
Drives: 2014 328i M-Sport, 2019 X5 40i
BMW oil part number for G05 40i
I just had an oil service done on my G05.
The part number and description they used for the oil is:
83-21-2-463-674 BMW group LL-17 FE+ 0w-20
I cannot find any information on this oil.
Two questions:
1) Have any of you had BMW put 83-21-2-463-674 BMW group LL-17 FE+ 0w-20 oil in during your G05 oil service?
2) What other oil has BMW used on your G05 for an oil service?
Thanks!
      10-28-2020, 02:31 AM   #2
jad03060
Drives: X5 45e
According to the user's manual, that is a suitable oil spec for the 40i engine, but I'm not sure the 0-20w oil versus the 0-30w is the better choice for your area. The manual lists three LL specs that are suitable for the 40i (and 45e) engines, and both 0-20 and 0-30 weights. Don't know the specifics on this engine, but the lighter weight oil is often spec'ed for colder areas, but may be entirely suitable for this engine. SF certainly isn't like northern Minnesota , or Alaska, but it's also not the middle of the desert in Arizona, either. The later specifications may provide all of the protection at 0-20w as the 0-30w did on older specs while providing less drag in the engine.
The manual says that BMW now recommends Shell oils. For years, they used Castrol. Don't know why they changed.
sygazelle11413.50
      11-17-2020, 07:45 PM   #3
guardodoc
guardodoc's Avatar
Drives: M3 e92, 1986 325e 2021 X5 40i
LL-17 FE +
83-21-2-463-674 Tried to track this part number down and it is only available in bulk, so I couldn't order 1 or 5 liter bottles
      11-22-2020, 06:35 PM   #4
misticdxx
Drives: BMW X5
I'm curious myself. i've been doing research on which oil to use and it seems like it needs to be either 0w-20 or 0w-30 but it leans towards 0w-20 and needs to meet the BMW LL17 FE+ specs.
The only oils that I could find that matches the weight and BMW spec is the OEM oil part number 83212461988 and LiquidMoly Toptec 6600 LM22046.
I was wondering if anyone has used the LiquidMoly oil in their B58 engine.
      04-02-2021, 08:04 AM   #5
Ferdinand14
Drives: 2020 BMW X5 x40i
https://www.getbmwparts.com/oem-part...J5IFBhZ2Umaz0x
83-21-5-A2A-FC5 replaces 83212461988
      04-02-2021, 08:08 AM   #6
Ferdinand14
https://www.amsoil.com/p/sae-0w-20-l.../#pills-home_0
Another option. Meets all the BMW requirements:
API SN-PLUS (Resource Conserving), SN, SM...
ILSAC GF-5
ACEA C5, A1/B1
BMW LL-17FE+
MB 229.71
Ford WSS-M2C947-B1
Opel/Vauxhall OV0401547
Fiat 9.55535-GSX
Chrysler MS-12145
Volvo VCC RBS0-2AE
xbimmers
