10-23-2020, 04:21 AM | #1 |
Rep 468
Unable to read head unit
I performed a base map version update from a third party company and now I can't access the head unit to finish coding an SLI emulator with Bimmercode.
This is what Bimmercode had to say: "The head unit has to be in its original state. If you used a third party solution to enable CarPlay or the navigation has been unlocked, these changes have to be reverted, because BimmerCode will not allow coding the head unit otherwise. Retrofitted iDrive systems may also not be accessible under certain circumstances." Is there a way to still access and code the head unit without reverting back? |
02-04-2021, 02:37 PM | #2 |
Rep 9
Bimmercode blames to other party, and other party blames bimmercode.
In the meantime we are stuck with it. Deleting and reinstalling everything on the phone did not help here. |
03-30-2021, 01:48 PM | #3 |
Rep 4
I have the same issue "coding head unit not possible because it is not in its original state".
I did use the same Feature Installer with the same code to successfully restore to OEM, but it did not help. I did all kinds of restarts/driving around, even installed and removed CarPlay again. I am using an ENET cable and an iPhone ethernet adapter to connect and all other coding went without any other issues. Please advise what should I do. |
03-30-2021, 04:37 PM | #4 |
Rep 611
Got the same after full retrofit of ID6 HU by authorized service. Not altered unit or features unlocked, as I have them all and I am even full ConnectedDrive subscriber.
Contacted Bimmercode support, provided them log data, and they've responded extremely quickly. However, their final conclusion was "the app is not able to verify the FSCs stored in the headunit. I can not tell why this is the case at the moment and there is no quick fix unfortunately." The only way would be using another software. |
04-21-2021, 08:31 AM | #5 | |
Rep 4
Here is their exact response: "Hi, after removing the CarPlay unlock, please delete the FSC folder on your device using a computer or the iOS files app." Meaning that first you should return the Head-unit to the OEM state (remove CarPlay) and then remove the FSC folder on your phone. I did it and it all works well. |
J555568.50 |
04-21-2021, 01:29 PM | #6 | |
Rep 33
04-21-2021, 03:21 PM | #7 | |
Rep 4
You launch this program on your laptop when connected to your car, you have to put the feature code, then click identify and start. It will ask you if you want to return the head unit to the OEM state. It takes 5 minutes. The laptop needs a solid connection to the Internet and you cannot interrupt the connection to the car as well. |
04-25-2021, 08:55 AM | #8 |
Rep 611
04-25-2021, 05:49 PM | #9 |
Rep 3,070
Best way is to use Esys
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
04-26-2021, 06:04 AM | #10 |
Rep 468
I used E-Sys too. Works much better. Plenty of Youtube video tutorials and info on these BMW sites to get you started. App is pretty easy to use actually after my initial hesitancy and concerns. Also much safer coding using an ENET cable connection versus Bimmercode WiFi or Bluetooth connection.
J555568.50 |
06-05-2022, 06:13 AM | #12 |
Rep 1
Hi
Very new to coding and BMWs. Got a 2018 330e and loving it. I have bluetooth audio but not office or can't connect 2 phones(on calls, can connect 1 for audio and 1 for calls). Anyway, I got bimmercode and a modbmw wifi enet to add them. The head unit is not appearing in the list on bimmercode. When you are all saying that head unit is not working, is it appearing and blank once you into it or not appearing like me? List of ecu's appearing. Thanks Will |
01-06-2023, 07:37 AM | #14 | |
Rep 3
Head Unit Access Denied
Last edited by rvolpe219; 01-06-2023 at 07:40 AM.. Reason: Copied my response by accident |
01-06-2023, 07:40 AM | #15 |
Rep 3
Hello. Please advise how you reverted. I am running into the same issues after installing a third-party Carplay unlock. I have a 2018 X3 xDrive30i, without wireless charging or wifi hotspot. Can it be done with BimmerCode?
01-08-2023, 12:57 PM | #17 |
Rep 611
Use the esys or ProTool (basically a user friendly esys in your mobile) and you should be fine. While I am not blaming Bimmercode, the ProTool is as easy to use, and so more capable, nobody will ever look back.
08-08-2023, 05:29 AM | #18 |
Rep 80
Another ones bites the dust... Had CarPlay activated via feature installer and right after that I can;t access the Headunit module via Bimmercode.
I followed this thread's advice and removed CarPlay, deleted the FSC folder on my Android phone (had to connect it to a pc to access the Android/data subfolders) but STILL, Bimmercode shows up the same erorr message of unit not being in its original state. So frustrating having paid for Bimmercode and having to purchase another app like the ProTool for 80$, only to be able to access one single module.... Has anyone found a work-around to this? Otherwise I think I will be buy tokenmaster's licence for 50$/3 year plan and try my lack with the real thing (E-SYS)... what other options are there? |
08-12-2023, 07:53 AM | #19 |
Rep 125
I'm in the same boat. I've been searching for a fix and this thread came up. I have a '16 330i which originally came with a ID4 and I retrofitted an ID6 a couple of years ago at a local garage and they activated Maps and CarPlay for me. I don't know what tool, FSC code, etc. they used to be quite honest but it's been working fine ever since.
I do use BimmerLink and BimmerCode for some coding, but I've noticed that I cannot really access the Head Unit from BimmerCode at all, because of the dreaded "Coding this control unit is not possible because it is not in its original state" error. I've contacted BimmerCode about it and still waiting for their reply. What are my options? I don't know what the garage did exactly to activate CarPlay and I don't really want to mess with that, but I want to be able to code the HU using BimmerCode? I also have an ENET cable I bought a couple of years ago but I heard that coding with ESYS is not possible anymore unless you purchase BimmerUtility. Can someone shed some light on this please? |
08-14-2023, 01:20 AM | #20 | |
Coding ECU's remotely
449
Rep 1,182
Using esys requires a Token solution, esys ultra is the best integration I've used. Esys is more difficult to learn than Bimmercode etc but way more powerful and flexible than the phone apps.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
04-02-2024, 05:42 PM | #21 | |
Rep 108
Downloading to my Samsung tablet now. $50 for BimmerLink, $50 for BimmerCode and now $80 for Bimmergeeks ProTool. https://www.bimmergeeks.net/protool Edit: It wont use my OBDLink MX+ and advising I use their Bluetooth Adapter at $50, so this is on hold for now. Last edited by 1004ron; 04-02-2024 at 06:00 PM.. |
04-05-2024, 04:00 PM | #22 |
Rep 538
Brought bmercode for a similar reason for NBT coding with id4. Did a id6 retrofit and hit the third party issue. Bimmecode wont even allow the most basic coding parameters on it in export mode. Easy $80 for BimmerCode. Now as about as useful now as a teapot 🤣
Gone to laptop coding via Bimmer Utility which is next level and can be relied on no mater what other coding I may do in the future. |
