11-11-2020, 10:35 AM | #23 |
Rep 822
It’s always interesting when people post what they state are the best settings for any audio.
Best advice is drive somewhere quiet, take a coffee then spend some time setting it up to your liking. We all hear differently. There are no right or wrongs at all. I worked in a hifi shop when at uni, and one of the directors made the only valid point I’ve ever heard and that was along the lines of “unless you listen to all music flatlined as recorded then you are changing it to suit only your ear. If you like it flat and it sounds crap you haven’t spent enough money” |
Ronstein417.00 |
11-11-2020, 10:38 AM | #24 | |
Rep 5
mcscoobs169.00 |
11-11-2020, 02:21 PM | #25 | |
Rep 2,047
https://www.amazon.co.uk/dp/B07VDQST...p_mob_ap_share Was recommended this as a cheaper Dynamat alternative: https://www.ebay.co.uk/itm/SOUND-DEA...Cclp%3A2334524 Last edited by winther1; 11-11-2020 at 02:45 PM.. |
11-13-2020, 02:04 AM | #26 |
Rep 565
https://www.focal.com/en/car-audio/c...mwr/isub-bmw-2
I installed these yesterday. Noticeable improvement straight away. Bass is controlled and comes in when it should. Previously the HK subs bass would appear at the wrong time and then linger as a back ground buzz or interference. I have upped the bass to check and it's a much resolved more bass. This isn't how I'd listen to it but it helps demonstrate the improvements. |
11-13-2020, 08:06 AM | #27 | |
Rep 2,047
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
11-13-2020, 09:35 AM | #29 | ||
Rep 2,069
HK amp will overheat & subsequently fail. 2 ohm woofers are not compatible with it.
/// BM3 + M-Power ///
11-13-2020, 11:17 AM | #30 | |
Rep 565
https://www.focal-inside.com/bmw/en/...2012-2018-f31/ "* Focal Inside solutions are compatible with most original hi-fi option (Standard, Top Hi-Fi, etc.) except for subwoofers from the Harman hi-fi option." Oh. So the term plug and play isnt quite right then if you have teh HK amp? I am sure the advice came from some where in this forum but I read it a while ago if I did read it. This sucks then. I guess I missed the bit about the HK amp not being compatible but the other amps were. Hey ho live and learn So solutions please? https://f30.bimmerpost.com/forums/sh....php?t=1763310 Bit pricey?! Last edited by flashollie; 11-13-2020 at 11:39 AM.. |
11-13-2020, 12:07 PM | #31 | |
Rep 2,047
11-13-2020, 12:42 PM | #32 |
Rep 2,069
Yeah, that Audison amp is great, but really for upgrading base audio. I don't think (off the top of my head) it's compatible with the MOST HK connection.
So, if you want to retain a plug & play solution, you ideally need 4 ohm woofers. The HK amp will drive those fine & because that's 3 ohms less than the stock woofers, they'll be louder. If you can't return the Focals, you may struggle to sell them on, being 2 ohm. In which case, you're going to have to think about keeping them & amping them separately, exactly as I did. Or, if you can send them back or sell them, think about just separately amping the stock woofers. They are good units with additional amplification. It really boils down to how much you're comfortable spending overall.
11-13-2020, 12:53 PM | #33 |
Rep 2,047
The 4-ohm ISUBBMW4 Focal subs:
Max. power 180W Nom. power 90W RMS Sensitivity (2.83V/1m) 83dB Frequency response 35Hz-200Hz For comparison, what are the specs for the HK subs?
11-13-2020, 02:31 PM | #34 | |
Rep 565
So I'm stuck with them and from what you advise looks like I amping them separately. Which you may not be surprised to hear sounds like it is beyond my current skill set. So what's my shopping list look like - I'm thinking of getting this done by a specialist. |
11-13-2020, 03:07 PM | #35 |
Rep 865
Type Subwoofer
Woofer 10" (200mm) Magnet Neodymium Cone Black Polyglass Surround Butyl Impedance 2Ω Max. power 180W Nom. power 90W RMS Sensitivity (2.83V/1m) 83dB Frequency response 35Hz-200Hz Specs taken from the Focal Website... wouldn't have expected them to make a mistake like Woofer 10" (200mm)... |
11-15-2020, 04:29 AM | #36 |
Rep 115
I've not had my car long, so I'm still getting used to the HK sound. But first impression is not great.
I was expecting much more. The focus had Sony. The Mazda Bose. So, after the first 335d came with standard audio I made sure the replacement had the HK setup. Both the Sony and Bose systems sounded better. It's not bad at low volume, but sounds disorganised at medium + volume. Just glad the six pot makes a nice noise. 😊 |
11-15-2020, 03:49 PM | #37 |
Rep 2,050
And there was me happy with the system having come from a 18yr old Honda CRV and a 17yr old rattly Impreza with no sound deadening and a 10+yr old Alpine headunit! It's not as good as some, and not in the league of the Meridian in my dad's Evoque but it's still decent enough IMO, certainly up to the max volume I would choose to listen at while driving...
11-16-2020, 01:17 AM | #38 | |
Rep 565
Any comments - is this decent kit and a decent price? |
11-16-2020, 03:39 AM | #39 | ||
Rep 2,069
As for the Amp... you can only go with what is compatible. You will have to take the fitters word for it. I don't know exactly how bridging works. That amp is rated to feed 4 x 130w @2ohm or 2 x 130w @2ohm + 1 x 260w @4ohm. So it may well be doable. It certainly looks a versatile Amp, and Audison is good stuff. But do properly double check. According to its spec sheet, it's NOT an option. Spec sheet is here: https://www.audison.eu/wp-content/up...Tech_Sheet.pdf I'm sure your fitter won't end up stuffing you, as long as they're reputable.
11-16-2020, 03:51 AM | #40 |
Rep 2,069
But as G50 has pointed out... CHECK YOUR WOOFERS!
If they're 200mm they won't fit no matter what. I doubt even with a spacer it'll fit, there's not much room before hitting the seat base. 180mm is the size needed for our cars.
11-16-2020, 04:00 AM | #41 |
Rep 565
Oh yeah thanks forgot, I did that they are in and fitted so they are definitely 180mm!
11-16-2020, 04:41 AM | #42 | |
Rep 2,069
Edit: Just looked again. The 10" size must be a typo. My bad, of course, 200mm is 8". I remember now, you said you had them fitted. I presume as they are, they're very overpowering & clippy? Driven from the HK amp?
11-16-2020, 05:14 AM | #43 | |
Rep 565
11-16-2020, 05:23 AM | #44 | ||
Rep 2,069
That's what I would expect tbh. Yeah, if you just leave them like that, they will probably deteriorate until the HK amp gives up & fries. Like I said, just check carefully if that Audison amp is actually compatible. I remember my choices were very limited. I was fortunate, as I like Hertz stuff, it was the first manufacturer I checked.
