Login
11-24-2020, 01:23 PM | #1 |
![]() ![]() ![]() ![]() ![]() 411
Rep 696
Drives: bmw M3 F80
M4 CS/GTS style taillights for F30 / F80
Hello,
I just placed an order for M4 CS/GTS style taillights. Hope the quality will be perfect https://fr.aliexpress.com/item/10050...55606c37QEy7nW Last edited by david51; 11-24-2020 at 01:36 PM.. |
11-24-2020, 02:20 PM | #2 |
![]() 585
Rep 1,421
Nice. Kind of iffy on the segmented led format. Idk if it's rocking well with the F30 rear. Likely because it doesn't look as wide as the 4. Photos on Aliexpress aren't bad though. In for pics. I still have my precli 3 lights
F30 335iX | Remus Axleback | 18X9 ET32 19lb TR-1 255/40/18 | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete
11-25-2020, 07:23 PM | #3 |
![]() ![]() ![]() ![]() ![]() 168
Rep 651
They're currently around £481.. cheaper than some of the depo variants.
Shame they don't do them for the 4er shape otherwise I'd have spent the cash
Current: F32 2015 435i M Sport - Alpine White - Scorpion catless DP, MPE with optional turboback straight pipe valve control, CF aero kit, Morph carbon valances, 405M's, 12 & 20mm spacers, retrofitted ICON headlights, retrofitted blackline LCI rear lights.
12-06-2020, 04:03 AM | #4 |
![]() 63
Rep 174
Yup that sucks they don't offer them for the F32 I'd buy a set of those for sure. All the good mods are for the F30 lol.
12-08-2020, 08:00 AM | #5 |
G
![]() 52
Rep 60
Drives: 2013 BMW 328i F30 Luxury Line
They have them in the U.S. on mashimarho.com for about a grand
12-08-2020, 11:13 AM | #6 |
A family of bimmers
![]() 2184
Rep 7,289
I assume this is for LCI only to be Plug and Play based on their description on ali express. and yes the markup on mashimarho is huge. I expect these will hit ebay for almost half that.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX 2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP |
12-08-2020, 04:49 PM | #7 |
Rep 696
Drives: bmw M3 F80
On each light there are 2 sockets one for lci and one non-lci of your choice
wdeerfield2183.50 |
12-09-2020, 03:03 PM | #8 |
![]() ![]() 19
Rep 60
Drives: 2014 BMW 335i M Sport
Sucks these don't have the correct style wing design with the break in them. ☹️
2014 335i Sedan | 8AT | M Sport | Black Sapphire Metallic
Past: 2011 335i Coupe | 6MT | Sport | Jet Black |
12-10-2020, 12:35 PM | #9 |
![]() ![]() ![]() ![]() 251
Rep 827
the one that dubsesd posted looks slightly different than the Mashimarho and ebay/aliexpress lights. not sure if his was a prototype that won't end up being produced, but i kind of prefer those as the top half/turn signal doesn't look as out of place
2013 335i (8AT, PWG) /// BM3 Stage 2, FBO: CTS Turbo FMIC, CTS Catless DP, ER CP /// Bilstein B14, OEM 437Ms, MP LSD, MP Brakes
02-07-2021, 11:31 PM | #13 | |
![]() ![]() 33
Rep 119
Drives: 2014 335i 6MT MSport MPPK MPE
Also yr insta link is broken. The depo fake black line lights just don’t look good. These do!
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE, Dinantronics Sport, BimmerTech CarPlay |
02-08-2021, 12:10 PM | #14 | ||
![]() ![]() 422
Rep 274
I got these from MashiMarho.com |
02-11-2021, 10:02 PM | #15 | |||
![]() 33
Rep 182
02-16-2021, 11:39 AM | #17 | ||||
![]() ![]() 422
Rep 274
Fit like 9/10 You do need to drill a hole to feed the wire and connect the inner and outer brake lights. Though you could just leave them unconnected and only have the outers work as brake lights |
02-18-2021, 06:56 AM | #18 |
![]() ![]() ![]() ![]() ![]() 552
Rep 894
That's because they've got the same shape inner pieces as the f32 lights, just in an f30 housing - doesn't flow well imo
you can see the difference in this pic ![]()
CURRENT: BSM 330D M Sport+, HUD, sunroof, Individual Opal White interior, BC Racing coilovers, HRE FF15 F:20x9 et25 R:20x10 et40, plenty of cosmetic/aesthetic mods
PREV:Melbourne Red 430i M Sport+ |
02-18-2021, 01:29 PM | #19 | |||||
Rep 14
02-18-2021, 07:56 PM | #20 | |
![]() 40
Rep 97
Highly recommend them tho, only problem I had was the day after I installed them, it snowed and some moron hit me while I was parked and broke my left side. ![]() Also, if you dont want to drill into your car, you can run the wire that connects to the trunk lights, thru the hole that is already there and cut off half of the tab that slots into the hole. Thats what I did and they fit great... Last edited by Dc444; 02-18-2021 at 08:02 PM.. |
SHUMAI1.50 |
02-18-2021, 08:05 PM | #21 | ||
Rep 14
I'm not quite sure what do you mean but the tab, I've never swapped my lights before but I've definitely read about having to drill a hole which worries me. |
02-18-2021, 08:46 PM | #22 |
![]() 40
Rep 97
V1 has the better animation but v2 has a cleaner OEM look.
I like the thicker lines of v2 as well. There is a predrilled hole on the car where you line up a tab on the outter lights, this can be used to run the wiring but it's not big enough for the wiring and tab to fit, which is why you either need to expand the hole or remove half of the tab. |
