12-11-2020, 11:37 AM | #1 |
Rep 15
Auto brake when wipers ON @ above 80km/h
Hello
My car is F30 2014 3.20ied with 1.6 liter 4 cyclinders engine. My car applies brake when the windshield wipers are on while moving with speeds above 80km/h. It makes me lose 10/15 km/h speed. The braking is not harsh and the duration of the braking is 2-3 seconds. Cruise control on or off doesnt make any difference. The problem is repeatable. I have searched the forums and some people point it to brake drying feature. The solution is suggested as dsc/abs ecu change, brake hydrolics change, abs hydro pump change or disabling it via software modification. None of these solutions is certain. Does my car have brake drying feature? How can this problem solved? Please dont say dsc/ abs ecu needs to be changed None of the technical services in my country has an idea. Im feeling very desperate. Note: My car has rain / light sensor Last edited by mehmetx; 12-11-2020 at 11:43 AM.. |
12-11-2020, 11:49 AM | #2 |
Rep 1,649
This is normal, some BMWs apply light braking to keep the brake rotors dry after x number of windshield wiper wipes. It should not be dramatic enough to show you down though. This is done to keep the brakes ready for immediate action in wet weather
Boznien289.50 |
12-11-2020, 12:00 PM | #3 |
Rep 15
This is the brake drying. But i shouldnt feel that brake. What i feel is definetely not normal.
12-11-2020, 04:37 PM | #4 |
Rep 2,852
Drives: F33 430 and F39 M35i
Have you visually and physically inspected your brakes to make sure nothing is wrong there?
I think you can code the duration or something. |
12-11-2020, 08:48 PM | #5 |
Rep 5,187
BMW's will drag the brakes a bit to dry the pads and rotors, but not once have I ever noticed it happening, only that the brakes do grab instantly when I manually apply them later.
If it's dropping speed, then something seems off for sure. |
12-12-2020, 06:17 AM | #6 |
Rep 919
Check your pads for wear. One may be hanging up.
You can also just drive at speed for a while and pull over without using the brakes to see if one rotor is hotter than another--in which case it isn't a 'system' thing, but just a caliper. If so, take it apart, check it out, maybe replace or rebuild, but at least, clean up and grease as appropriate.
12-12-2020, 08:24 AM | #7 |
Rep 15,857
Definitely fits 'over pressure' braking, during the brake drying function. If by repeatable, you mean about every 90 seconds, then that is definitely indicating it is happening during brake drying.
Pressure should be only about 1bar, unnoticed by the driver. Does the car immediately 'free up' after the couple of seconds of retarding? Or is it dragging? |
12-12-2020, 11:40 AM | #8 | |
Rep 15
When the car brakes itself, it doesnt allow me to accelerate for that 2-3 seconds to compensate the braking even tough i hit the acceleration pedal. After that 2-3 seconds of auto brake, it frees up and i can accelerate again |
12-12-2020, 12:00 PM | #9 | |
Rep 15,857
I suggest that the pressure application is too high. As said in my previous post, it is only supposed to be ~1bar, not enough to be noticed by the driver. The exact cause... I can see your problem, with the average garage. Needs someone who really knows the braking (and ABS) system design/function. Follow the trigger sequence and where there is a possibility of the pressure regulation being misapplied. |
12-12-2020, 12:58 PM | #10 |
Rep 463
Have you changed anything in the brake system or is it compete stock? Is there a chance that a caliper is sticking ?
12-12-2020, 01:03 PM | #11 |
Rep 15
Everything is stock, nothing is modified. I will have the calipers checked asap. But there is not any problem when i apply brakes by myself. If the calipers sticked, wouldnt i feel problems when i brake?
12-12-2020, 01:19 PM | #12 | |
Rep 392
12-12-2020, 01:25 PM | #13 | |
Rep 15
Everything is perfect when the wipers are off. When brake drying does the car cut throttling even though the pedal is pushed? Is the normal brake drying fuction working this way? |
12-12-2020, 01:30 PM | #14 |
Rep 833
Drives: BMW F36, E36, E93
Did you get the error log read?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
12-12-2020, 01:44 PM | #15 |
Rep 15,857
My trouble shooting path would 99% eliminate the calipers, due to it only happening when the wipers are on and the 'link' is to the intermittent brake drying function.
12-12-2020, 01:49 PM | #16 | ||
Rep 15,857
To quote BMW: Quote:
12-13-2020, 01:00 AM | #18 | |
Rep 15
At the moment im praying that it wont require dsc/abs ecu change as they cost a lot ( |
12-13-2020, 01:30 AM | #19 | |
Rep 15
12-13-2020, 08:43 AM | #20 |
Rep 15
I have driven like 20 minutes and didnt brake by myself too many times, it was like 3-4 times braking. When i stopped, i checked the rotor temperature by touching. They are much hotter than my body temp. I guess they are above 50 C degrees Celcius (122 degrees Fahrenheit). The ambient air temp is around 9 degrees Celcius (48 Fahrenheit) degrees and it was raining.
I suspect that calipers are sticking to the rotor and making it heat up. And eventually this causes a lot harder braking than its supposed to be during brake drying. Am i right? |
12-13-2020, 09:03 AM | #21 | |
Rep 15,857
There will be heat from any braking. Your description appears totally normal for the conditions. What you'd be looking for, is likely one caliper sticking and a lot of heat (untouchable) in the rotor/disc. But you'd feel that from any braking, given what you report for the retarding experienced. If you didn't have any feeling of sticking brakes after braking, the actual brakes aren't likely any part of the issue you are experiencing. Think "switching on wipers", and its related function to the braking system, that is your biggest clue to tracing the fault. |
12-13-2020, 09:19 AM | #22 |
Rep 283
Exactly this
Only does it when wipers are on means absolutely it is an issue with the dry braking system, might be possible to code the amount of pressure exerted on the calliper pistons by the ecu. |
