01-08-2021, 09:05 AM | #1 |
Rep 757
Door wont open
Hi All, I'm in kind of a weird situation.... my front drivers side door will not open from the outside or the inside of the car. Any advice on how to get it open ? i get the "take the to the dealership" but is there anything i can do to get it open and replace the door lock actuator my self ?
2014 Estoril Blue II BMW 328i xdrive ///M-Sport
01-08-2021, 09:46 AM | #2 |
Rep 844
pulling the handle twice from the inside doesn't work? Is the physical lock on the top of the door card up? Have you tried unlocking with the key fob? Not sure how you will be able to remove the door card if you can't open the door at all.
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
01-08-2021, 10:06 AM | #3 |
Rep 757
when you pull on the inside door handle you can see the lock goes up but it doesnt stay up. Even if you hold it up and try opening from the outside does does not open. As far as the keyfob it opens the other 3 doors but not the drivers side.
01-08-2021, 10:13 AM | #4 |
Rep 844
that is peculiar. But it sounds like the lock is actually functioning if the lock goes up.
The only other things I can think to try before going to the dealer is to unhook the negative terminal from battery to reset electronics. maybe there is a way to unlock it with ISTA if you have that but I honestly am not sure.
BWbimmer276.50 |
01-08-2021, 10:19 AM | #5 | |
Rep 757
01-08-2021, 11:08 AM | #6 |
Rep 614
Drives: 2016 F36 M Sport
This has been discussed on the forums before and seems to be a pretty common issue. It happened on my previous BMW but it was intermittent and I never did anything about it. I think you just need to replace the actuator, like you mentioned. As far as instructions, I don't immediately see any DIYs on the forums, but maybe search YouTube as I think others have found help on there.
And of course, if your car is under warranty, then "take it to the dealership"
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
01-08-2021, 11:16 AM | #7 |
Rep 844
I would have the passenger door open and unlocked, then pull the negative terminal and see if you could slide into the driver seat with the negative still un attached, double pull the driver handle to open the door. If that doesn't work i would hook up the cable again and repeat the same steps. If neither of that works then I'm out of ideas lol. good luck! keep us posted
01-08-2021, 11:38 AM | #8 |
Rep 975
This was the exact symptom I had of a failing actuator. Fortunately replaced under warranty but ONLY after providing video proof.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
01-08-2021, 12:22 PM | #9 |
Rep 757
thanks for reminding me to take a video of this !
Fliplegend1471.00 |
01-09-2021, 04:59 AM | #10 |
Rep 878
Have you tried using the central lock/unlock button? When my actuators were unreliable and a double pull wouldn’t open the door I found that hitting the central lock/unlock would always work. Yep really strange as if the actuator was faulty or starting to develop a fault no idea what pressing the button would work.
01-09-2021, 09:47 AM | #11 | |
Rep 1,560
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
01-09-2021, 11:12 AM | #12 |
Rep 16,099
Take the electronics out of the equation by unlocking the door with the physical key. If it still won't open the problem is in the mechanical linkage.
frazervalley125.00 |
01-09-2021, 02:21 PM | #13 | |
Rep 757
01-09-2021, 02:22 PM | #14 |
Rep 757
thats what im thinking, ill be taking it in on Monday.. hope they have a way of getting the door to unlock LOL
01-09-2021, 06:08 PM | #15 |
Rep 359
What are the odds!!!! I juts read about this issue, and my BMW decided to have the same problem!!!!! Looks like I will have to take it in to the dealer! How much damage can I expect?
01-10-2021, 09:49 AM | #16 |
Rep 757
i'm expecting about $550 but you know how that goes ... might be more lol
01-10-2021, 10:55 AM | #18 |
Rep 757
only because i do not know how they are going to unlock my door to take the door panel off. I'm hopping that they have some kind of a trick but we will see.... hoping for minimal damages on the wallet.
01-10-2021, 03:06 PM | #19 |
Rep 359
01-10-2021, 03:38 PM | #20 |
Rep 4,453
Drives: '23 X1 28i xDrive
lock actuator. lots of threads here about it
01-11-2021, 12:07 PM | #21 |
Rep 757
so got a quote... you'll be looking at around 600-700 all together. 315 of that is just to diagnose and break into the car to be able to get the door panel off. Once they have the panel off they'll have an idea on what actually broken.
01-11-2021, 12:09 PM | #22 |
Rep 757
yeah looks like a simple job to replace it.... i just wish my door wasn't shut closed. Looks like for most people when it happens you cant lock the door so you still able to open and close it. I'm just the one of the few unlucky ones where you cant unlock the door.
