01-11-2021, 04:02 PM | #1 |
Rep 7
Coolant loss 2014 435x
Had white smoke on startup and a misfire on cyl 3 after sitting for 5 to 20 minutes after warm. No spots on ground, had it in the air and no visible signs of leaking externally, no milky white in oil done 4 oil changes (liqui-moly) and not a spot of moisture, no oil in coolant.
Replaced the tank cap, ofhg and oil cooler gasket w orings. Now very little smoke at start, adding a 1/4 gallon coolant every 3-5 days depending on how spirited I drive and runs at a cooler temp at idle than at any speed after warm. Any advice what to look at next? Hoping not head gasket. coolant system pressure test was normal. Thank you |
01-11-2021, 06:19 PM | #2 |
Rep 7,733
Were you driving hard before all this started the first time? Hate to say, but white smoke in exhaust typically only means one thing... coolant into the combustion chamber. And if you have continued coolant consumption with no leaks, that also points to head gasket, especially if consumption increases as you drive harder.
If you are talking about pressure testing the coolant system to say, 15-20psi, thats generally not enough to reveal a head gasket leak (unless its really bad). Did you test your coolant for traces of combustion products? Any coolant smell in exhaust to accompany the smoke? |
Billfitz8619.50 |
01-11-2021, 09:56 PM | #3 |
Rep 16,672
A leak into a combustion chamber probably wouldn't show up in the oil. If you've ruled out all the other possibilities then it's probably the head gasket.
01-12-2021, 01:06 PM | #4 | |
Rep 7
01-12-2021, 02:36 PM | #5 |
Rep 7,733
01-12-2021, 08:49 PM | #6 |
Rep 10,614
Although a rare occurrence, N55 turbocharger can exhibit a leak in two places:
- Turbo coolant lines - Turbo coolant housing can crack - suggest to perform a thorough inspection Keep us updated! |
antifreeze, coolant, coolant loss, headgasket, ofhg, thermostat |
