BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - Southwest > Solved. Seats installed! Looking for handy electrician in Houston or Texas.
      02-18-2021, 06:40 PM   #1
Kolianovskyi
Drives: BMW 650i
Update. Was able to to it by myself, so front seats from 650 are now installed and wired in my 435. See below.
Hi!
I have bmw 435 2014 and would want to replace front seats with a pair from 650. Not sure if coding is the only one what would be needed for a driver seat, but for passenger seat, as it does not have memory in stock and a new one does have, a k-can bus (two cables), would need to be added as well.
I have all electrical schemas to support. Looking for help to wire new seats and code/clear airbag errors. Could drive from Houston to a shop if any.
P.S. I also ordered an original wire harness from 650 for these seats to replace my own if any.
Last edited by Kolianovskyi; 03-18-2021 at 03:15 PM.. Reason: Solved a problem. Mistype.
      02-22-2021, 05:34 AM   #2
Kolianovskyi
Drives: BMW 650i
Ok. I did install driver's seat already. It is working. The next stop is to connect/code SRS properly to remove error message.
      03-18-2021, 03:16 PM   #3
Kolianovskyi
Drives: BMW 650i
I did install front seats from 650 to 435. Everything works. No errors.
