02-20-2021, 06:00 AM | #1 |
Rep 33
X drive suspension ?
Sure it’s been asked before but could anyone confirm what springs are on the LCi f31 x drive?
Is the ride more comfortable than non x drive? Thanks |
02-20-2021, 06:38 AM | #2 | |
Rep 5,392
When a car is being built at the factory they take into account the weights of standard and optional equipment and choose the optimal front and rear spring combination to install on the car. But the root of your question seems to be that you are assuming that your springs are causing an uncomfortable ride. It's likely that they are not. About half of the harshness of the F3x ride comes from the stiff sidewall of the runflat tires. Put regular tires on it and rough roads won't be as bad, potholes won't feel like craters and highway road seams won't feel like 4"x4"'s. They will feel rounded off like 2"x4"'s. The best summer tires are Michelin Pilot Sport 4S. For all seasons: Michelin A/S 4 or Continental DWS06. The stock struts and shocks contribute to the stock harsh ride. They're just cheap! An excellent high tech replacement are the Koni Special Actives. They are very comfortable yet sporty when you hit a curve. Koni designed them with McLaren. If you want to change springs I highly recommend Eibach. They have a moderate drop that's only 10% stiffer than stock so they won't add to harshness. Hope this helps! |
02-20-2021, 06:54 AM | #3 |
Rep 33
Thanks for your detailed reply.
I currently own an F30 m sport which I’m running 18” non runflat winter set up.Yes it’s a lot better than the 19”s on runflats,but still find it a bit fidgety and uncomfortable on bumpy surfaces. I’m in the market for a touring so that’s why I was wondering if the x drive might have the SE springs which I would imagine are softer.Not bothered for improved handling and sportiness I just prefer comfort in my old(er) age. Also looking at an A4 b9 on comfort springs always a bit bias towards BMW. Wanted to put a dog in the boot so can’t be doing with a whingy dog on long journeys. |
02-20-2021, 07:34 AM | #4 |
Rep 944
Can't be certain in regard to LCI springs on X-Drive, but I haven't ever read that they differ compared to pre-LCI springs.
My 2015 X-Drive came with springs that were longer than non X-Drive models. (People on this forum often state they are 10mm longer than the non X-Drive versions.) The car certainly sat tall on them and soaked up bumps, but the body control was lacking. It's something you would need to test drive on roads you know to make a decision whether it's right for you. |
02-20-2021, 08:04 AM | #5 | |
Rep 3,066
and you don't have to sacrafice comfort for good handling |
LobB5109.00 |
02-21-2021, 10:01 AM | #6 | |
Rep 5,392
02-23-2021, 08:28 AM | #7 |
Rep 289
My xdrive and my previous xdrive both give a 'softer' ride even on 19" wheels with runfflats compared to the RWD 4 series I've driven. As others have said the car sits about 10mm higher as well so more ground clearance. Perhaps not as sporty as a proper M sport and a little more 'bounce' but very comfy on my boney bum!
02-23-2021, 02:25 PM | #8 |
Rep 36
Just recently fitted my F32 xdrive with Eibach pro’s. Original OEM springs were “FH” front, “GM” back.
Eibach backs have dropped the car 12mm but fronts havent done anything🤷*♂️ |
02-24-2021, 10:12 AM | #9 |
Rep 724
I had the same problem with my F36 xdrive with Eibach Pro's which i had fitted last August, my rears dropped the stated 15mm but the fronts only dropped 8-10mm. Would have preferred the stated 20mm drop or at least the same as the rears, but i now feel the balance is just not quite right so will probably have to go down the route of changing the shocks, something to look forward too when all the madness starts to go away
02-25-2021, 01:39 AM | #10 |
Rep 8,780
If comfort is the priority, I think the 3 series is probably the wrong choice. Within brand, how about a 5 touring instead?
I'm not sure an Audi would be on my list of off brand alternatives for comfort. I've never driven a car with worse ride than an A4 I tested, albeit a B8.
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
LobB5109.00 |
02-25-2021, 02:02 AM | #11 |
Rep 33
I am considering a 5 series F11.Just can’t help thinking it looks dated now.🤔
My previous car was an Audi B8 dynamik and I found that much quieter and actually a better ride even on 19’s.Maybe a bit more Crashy but not as fidgety. Would rather stick with BMW.The A4 need to be a good spec otherwise look very boring I think. |
02-25-2021, 03:19 AM | #12 | |
Rep 3,876
Do you have a photo of yours from the side? Curious to see whether it looks similarly, with a hanging ass...
02-25-2021, 02:56 PM | #13 | ||
Rep 2,069
Pretty even drop front/rear IMO...
/// BM3 + M-Power ///
02-25-2021, 06:39 PM | #14 | |
Rep 724
02-25-2021, 06:44 PM | #15 | |
Rep 724
It was the reason i went for the Eibach's as that stated drop would be 20 front and 15 rear , where as ACS state 25 front and 20 rear, and i didn't want the front diffuser catching on the kerb as i reverse up the drive. Last edited by APJ; 02-25-2021 at 06:51 PM.. |
02-26-2021, 01:31 AM | #16 |
Rep 3,876
Thank you for the photo! Mine coming soon with comments
I have never seen ACS define their drop as specific as you state for front and rear! This is straight from their website: Tieferlegung VA ca. 20 - 25mm Tieferlegung HA ca. 20 - 25mm So approx. 20-25 front and rear. In reality not just ACS, but no one can promise you a drop down to a mm. Not even down to 5mm. The actual drop per axle depends heavily on your vehicle (configuration, weight, engine, etc).
02-26-2021, 03:29 AM | #17 |
Rep 3,876
Full exposure then
The front looks pretty much as yours, what do you think? The rear however is definitely lower than yours I'd say... Be assured that in time nothing goes higher. If anything - yours became even lower. But most likely it hasn't or not appreciably. Best would be to measure the distance from the centre of the wheels vertically to the arch. Then we can compare more precisely. Spoiler alert - I have more than 1,5 cm difference front and back....
02-26-2021, 04:02 AM | #18 | |
Rep 724
Yes the figures i quoted are approximate, but they have been quoted on here many times, and i think by Lorcan as well who appears on here many times and who actually works for ACS or for a company who sells their goods and has quite extensive knowledge of all ACS products. Maybe its worth asking him if anything can be done. I have seen other vehicles with ACS springs that are almost as low, and that is what put me off ACS, which is a big shame as all-round they are probably the best lowered springs for our vehicles. (I know others will now come on and say others are better, but going off the general consensus on this site) Last edited by APJ; 02-26-2021 at 04:07 AM.. |
02-26-2021, 04:22 AM | #19 |
Rep 3,876
Yes. And I can show you what it looks like with 2 persons sitting in the back, but you can imagine, I am sure
Lorcan is certainly very helpful and knowledgable. He has however already taken a position, which (surprisingly or not) is in line with ACS official position A. The cars have reverse rake from factory (not true in my case or at least definitely not to that extent). B. ACS springs drop the car approximately evenly (clearly not true in every case) C. The drop (I suspect no matter what, but at least mine specifically) is all within tolerance D. The front arch is made bigger to ensure the free turning of wheels, which creates an optical illusion (I am not convinced about that, my measurements don't support this theory) Did you expect anything else? And some of the above is certainly true to some extent - e.g. I have a heavy configuration. Probably the heaviest possible F36. The tow hitch installation alone is about 30kg, from memory... And YES - there is something which can be done for the rear axle! This is also the recommended mitigation by ACS (I got in touch directly with Aachen), who suggested it as I complained about the uneven drop. You can install the so called "Poor Road Package" spacers (original BMW), which will lift the rear with 6+ mm. Many people in Germany have them installed in combination with the ACS (Eibach) springs. I still haven't done so, but am more and more inclined to do it. I have the spacers already. The spacers are 6mm thick, but I have read people claiming the actual lift is a few mm bigger... I can't understand where the extra lift would come from, but even 6 is better than nothing I guess...
02-26-2021, 04:55 AM | #20 | |
Rep 15,858
Front wheel arch gaps are typically more, as mentioned, by design. Optically it gets much more sensitive as you close the gaps. Tolerances will show even more. BTW, BMW have springs matched to options. Even a panoramic roof in a touring changes the spring specification. So anyone just buying "a part number" for a model will have variations. |
02-26-2021, 05:48 AM | #21 |
Rep 3,876
Agree. It should be noted however that ACS have different set of springs within a certain model, depending on the engine. Which makes perfect sense.
In the example above, the 430d xDrive, 435d xDrive, 435i xDrive and 440i xDrive share the same set. 420i xDrive , 428i xDrive, 430i xDrive, 435i, 440i, 420d xDrive and 430d have a different set. And even so.... the result is suboptimal for some....
02-26-2021, 06:13 AM | #22 | |
Rep 15,858
The other factor as you have mentioned, is actual measurements. Requires a flat surface, more a workshop floor, than roads or parking areas. |
