03-08-2021, 12:45 AM | #1 |
Rep 7
Clutch pedal vibration
Hello, I recently bought a 2014 435i with about 48k on the clock. Have had the car for close to two months and in that time I have changed most of the fluids.
I have done the oil, mtf, and diff fluid as well as bled all of the brakes and clutch. Just after the mtf/diff/oil change and before the clutch bleed, I noticed a strange sensation in the clutch pedal. It feels as though the pedal is vibrating? Almost a gritty feeling when pushing in and releasing the clutch. I figured a brake fluid flush would help with the sensation, didn't do much. I filled the transmission with BMW spec lt5 fluid, I used about 1.3l roughly maybe a bit less. This seems like too much of a coincidence to not be related to the fluid change. Any suggestions? I would hate to think that the clutch and throw out bearing are showing their age with the cars mileage. |
04-16-2021, 01:44 AM | #2 |
Rep 7
Bump, I changed the brake and clutch fluid about a month ago. Still the same issue.
I have two ideas: The slave cylinder is bad Throwout bearing is done, and is more noticeable due to less friction from the oil change. I can hear a slight chatter, very slight chatter when in the garage and when the car is warm. Any ideas? This one eludes me. Ive search everywhere. |
clutch issues, transmission fluid change |
