03-08-2021, 05:21 AM | #1 |
Rep 87
Drives: 2014 335i Xdrive
Bm3 stage 1 boost increase
I just wanted to know how much the boost pressure is increase when going from stock to stage 1 on my 2014 335i xdrive n55. I know stock pressure is around 7psi
Can my stock turbos reliably handle stage 1 and stage 2 with supported mods(charge pipe, intake, downpipe, fmic ? |
03-08-2021, 07:04 AM | #2 | |
1322
Rep 3,593
yes, the turbos handle it just fine. the stock ewg turbo (you have just one, not two) max out at 20ish psi before falling off at high rpm. You're fine.
2017 m240i xDrive 10.67@132.32mph w/bm3
03-08-2021, 10:28 AM | #3 | |
Rep 194,456
03-09-2021, 10:51 AM | #4 |
Rep 63
I am usually around 15 -16 psi full boost on Stage 1 BM3. Definitely looking to get a high flow DP soon and move up to stage 2 to see that increase too. I installed CP and IC before moving to stage 1 just to keep from parts failing hopefully.
2014 335i M-Sport, CTS intake, VRSF FMIC, VRSF CP, BM3 stage 1
03-09-2021, 11:52 AM | #5 |
Rep 7,733
Yeah, just get IC+CP before stage 1, then add the DP if you want to go stage 2.
Also, stock can be higher than 7. It's a load-based tune, so boost varies to meet load target. Ive seen over 9 in my logs and i think as high as 11. |
03-09-2021, 12:17 PM | #6 | |
Rep 93
I don't really get on it to be honest, at least not till I get the chargepipe, inlet and intercooler replaced. If anything stage 1 made it bearable for me to daily. |
03-09-2021, 05:10 PM | #7 | ||
1322
Rep 3,593
14F30Daily9.00 |
03-10-2021, 09:49 AM | #8 |
Rep 194,456
+1
03-10-2021, 01:22 PM | #9 | |
Rep 93
Mike, Do you know of any fitment issues between the FTP charge pipe/boost pipe and the ATM FMIC? Thanks |
03-10-2021, 03:52 PM | #10 | ||
1322
Rep 3,593
03-11-2021, 02:03 AM | #12 |
1322
Rep 3,593
ah. get it replaced asap! it will break and leave you stranded. honestly you should flash back to stock till you swap it out.
11-09-2023, 08:01 AM | #13 |
Rep 2
BM3 Stage 1
Any bimmer who know how to read log can help me
Mods : HighFlow drop in filter, catless downpipes, cutback full exhaust system 2.5 inch Car Spec : F30 320i N20 PWG |
11-09-2023, 04:53 PM | #14 | |
Rep 7,733
https://f30.bimmerpost.com/forums/sh....php?t=1732327 |
