View Poll Results: Would be interested in buying this as plug & play kit? | |||
Yes | 80 | 95.24% | |
No | 4 | 4.76% | |
Voters: 84. You may not vote on this poll |
04-12-2021, 05:33 AM | #1 |
Rep 27
Custom ambient light module with multiple colors
I wanted to upgrade the ambient lights on my f30 LCI, so I started looking for options to increase both brightness and color options if possible. I like everything to look as oem as possible, so I didn’t want to use kits with rgb strips/flexible light pipes over the trim, or to replace the door trims with ones that have rgb strips beneath them. For a while I considered replacing the led modules only, with the ones from benzinfabrik, but I eventually gave up on this due to things like the total price for all modules, the unavailability of the dash trim modules and the fact that I would still only have 2 colors.
So I decided to build something custom, using a microcontroller board and some sort of rgb leds. I used a digispark for the controller and ws2812 leds from a strip for the light modules. Advantages of this setup: - the digispark is tiny and cheap(around $4) while still having enough inputs/outputs for this project - any colors can be programmed as options and they can be changed in the car - ws2812 leds only need 3 wires to display any color, which means there’s no need to replace the original wires running to the lights(I have the ambient lights pack with 2 colors = 3 wires, orange+white+ground) - the original optical conductors will be retained, only the led modules need to be replaced How this works: the ambient light cables for the orange/white colors come from 2 pins on a plug in the front electronic module(from there it splits along the way for the dash, doors, footwell and b-pillar lights if you have them). This module comes between that connection - it uses the orange/white light cables as inputs; for the outputs, instead of passing that voltage further, it sends 5V and data signal for the ws2812 leds, on the 2 cables going to the lights. How the colors are changed: when classic(orange) is selected in the idrive lights menu, the module simply displays the current color; when sport(white) is selected, the module cycles through the predefined colors, for a few seconds each one; selecting classic again memorises the color and displays it continuously. Indeed this control method is a bit rudimentary but I wanted to have the lights controlled through the idrive without any external switches, so this is what I've ended up with. It is a bit of work but I think the end result is worth it. If anyone has the patience and time to do something like this, let me know and I can write a full diy, with all the parts and tools needed. UPDATE: DIY guide - current sections: - parts & tools - power options with circuit diagrams - programming the board - test circuit - controller board instructions - radio trim led modules + in-car testing Coming soon: - installation - door leds - footwell leds Here are some photos of the dash trim and door modules(footwell leds in progress), door light and dash trim light. I'll take more photos and attach them in the second post. Last edited by cozzzz; 05-17-2021 at 01:02 PM.. Reason: updated completed diy sections |
04-12-2021, 05:34 AM | #2 |
Rep 27
I uploaded a quick video showing how the colors are changed and also showing the ambient lights turning on/off together with the car's lighting:
https://www.youtube.com/watch?v=Q0z1nVmANB4 I made an album with more photos as well, so I don't flood this post with large images: View post on imgur.com Note that the photos with the footwell lights are made with a different phone so they look a bit different. Also I think these are a bit too bright and might need some dimming, as I can see my legs more than I want when driving at night Really liking this light blue Last edited by cozzzz; 04-17-2021 at 08:19 AM.. |
Onizukachan1088.00 |
04-12-2021, 09:50 AM | #3 |
Rep 614
Drives: 2016 F36 M Sport
Definitely interested in seeing the DIY! Do you think these LEDs are as bright as the benzinfabrik ones? Or at least brighter than the OEM? Also, did you already have the OEM radio trim lighting?
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
04-12-2021, 11:22 AM | #4 |
Rep 27
Yes it had the radio trim lighting from the factory. The new leds are definitely brighter that stock, the door lights were barely visible before(even if the car is an LCI). I don't know how they compare to the benzinfabrik ones though, as I don't have any module from them.
04-12-2021, 07:35 PM | #5 |
Rep 1,791
This is super cool. I'd love to see a DIY as well. I have the Benzinfabrik modules installed currently but may just give this a shot sometime. Talk about some outside of the box thinking lol love it!
04-16-2021, 02:29 PM | #7 |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
Beautifully done and executed! Hats off to you!
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
04-16-2021, 09:54 PM | #9 |
Rep 1,687
Drives: 2014 428i and 2018 X5
You gotta specific link to purchase the controller?
04-17-2021, 08:16 AM | #10 |
Rep 27
Thanks guys, appreciate it!
Added new links to a video and a photo album in the second post, will start working on the diy guide. Might take some time to finish though, will keep updating as I go. The controller is a custom built part, same as the led modules, but the most important part of it is the digispark, you can buy it here for example. For reference, below is what my board looks like, before going in a box in the car. Might look complicated, but it's really not: - tiny usb board is the digispark - the blue rectangular board is a step down dc-dc converter (optional - if choosing to power the board directly to 12V) - the 4 resistors are there to make 2 small voltage dividers for the digispark inputs Everything else is just the prototype board, few wires and connectors. The orange/white cables are the inputs(from the car), the blue/red wires are the outputs(going to the lights). The 2 pins left unconnected are for power. |
04-22-2021, 05:43 AM | #11 |
23
Rep 388
Drives: F30 328i, M-Sport, 8AT
I would love to see a DIY for this. It looks brilliant! Would be very interested in doing it on mine as well!
04-24-2021, 01:37 PM | #12 | |
Rep 27
SirMoo3.00 |
04-28-2021, 10:03 AM | #14 |
Rep 27
Hey guys, I've added some new parts to the diy guide, including the circuit diagrams and steps to program the digispark. I'm working on the building steps for the controller board next. Meanwhile if you have some experience with electronics and want to start before that, you could build the board using the circuit diagram and reference photo
04-29-2021, 12:47 AM | #16 |
Rep 864
there would be a lot of people who would find this above their skill level. Also a lot of people to lazy to take on such a project i.e. me and I did electronic engineering for my bachelors degree lol
Would you consider selling kits? |
04-29-2021, 04:58 AM | #17 | |
Rep 27
Regarding selling this as a kit, I've though about it and while it's possible, I need to do some research on regulations about selling electronic devices, to find a supplier for PCBs and a few others. Also the first thing would be to see if there's any demand for this, maybe I'll add a poll about this. |
04-30-2021, 07:16 PM | #18 | |
Rep 1,791
If the LED's are brighter than OEM and preferably as bright as Benzinfabrik's modules, I'd definitely buy a kit. |
05-08-2021, 03:27 PM | #19 | |
Rep 27
Regarding brightness, these LEDs are definitely brighter than OEM (now I regret not taking before/after photos..). To my eyes the brightness level seems perfect as in bright enough without being distracting during night driving. I don't know how they compare to the benzinfabrik ones though. From what I've read and seen in photos, those might be brighter than ws2812 leds, but without actual lumens rating or comparing side by side, it's hard to tell. |
05-16-2021, 06:08 PM | #20 | |
Rep 1,791
Is there any way to use brighter RGB LED's in your kit? Not saying these aren't bright enough at all as they look adequately bright especially given that the OEM LED's are super dim even in LCI cars, but the brighter the better since you can always turn down the brightness in iDrive but you can't make them brighter ya know? Hopefully there is enough interest and you can make some kits to sell. Out of curiosity, how do you change the color via iDrive with your kit to say blue? I read your instructions on how the colors change but I didn't quite understand how it toggles colors. Please excuse me if I'm being dense lol. |
05-17-2021, 01:26 PM | #21 | ||
Rep 27
About using brighter LEDs, I've done some research on commercially available programable LEDs and so far I've only found 2 other models, both of which are smaller(and presumably not so bright). Other option would be to fit 2 LEDs per module, but that brings up some other issues like focusing the light from 2 LEDs into the optical conductor and available space inside oem led module housings. I'm still doing research to find the best solution on this. Meanwhile I found a local supplier for custom PCBs, only things left now are to design the circuit board, the led module boards, design and (most likely) 3d print module cases, purchase bulk components, assemble those components, custom wiring looms, packaging, instruction manuals, shipping...did I miss anything? Pretty sure I missed something Last edited by cozzzz; 05-20-2021 at 10:21 AM.. |
