04-18-2021, 01:10 PM | #1 |
Rep 16
Diff oil question
Hi,
I want to change the rear diff oil in my 2015 F31, found the original oil (83222295532) on realoem, it costs a fortune (or, around 100EUR for 1.5 liters) 😅 Would Castrol Syntrax Longlife 75W-90 be alright for the rear diff? Its around 30EUR for 2 liters, so quite a different price. Thanks! |
04-18-2021, 03:23 PM | #2 | |
Rep 241
04-18-2021, 03:26 PM | #3 |
Rep 16,128
The BMW fluid is 75W-85, so that's close enough. To be sure if it's OK you need to find the API rating on the BMW fluid and see if the Castrol equals or exceeds it.
04-18-2021, 04:24 PM | #4 |
Rep 417
2003-present xDrive Models (ATC Transfer Case)
BMW recommendation: DTF-1 (previously TF0870) 75W GL-4 All Front Differential BMW recommendation: SAF-XO, 75W90 weight, GL-5 rated Our recommendation: Red Line 75W90 - LIQUI MOLY LM2048 75W-90 Gear Oil Rear Open Differential, after 7/2011 production* BMW recommendation: G1 synthetic, 75W85 weight, GL-4 rated Our recommendation*: BMW G1 if under warranty, Red Line 75W85 GL-5 (Red Line-approved) - LIQUI MOLY LM2048 75W-90 Gear Oil I put Liqui moly in both front and read diff. I would stick to a GL-5 75W85 or 90 gear oil. Rear diff had no drain plug you need to bend a tube and suck the oil out. And you are supposed to replace the plug with a new one... What a waste.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
04-18-2021, 09:02 PM | #5 | |
Rep 5,395
FYI- the Bentley manual says that BMW recommends only using rear differential fluid with SAF-XO designation. If you use another fluid then check for that. It's usually a suction through the fill hole procedure. Tightening torque on plug is 60 Nm (44ft-lb) Note: it's interesting that according to realoem, the stock rear differential for my 2015 335ix automatic takes 1.5 liters of BMW fluid part number 83222295532. The Bentley manual doesn't list a rear differential fluid capacity (but is says the front differential takes 600ml) But I know that my rear M Performance Limited Slip Differential only takes 1 liter of BMW differential fluid part number 83222357992. So the extra LSD components must take up about a half liter of physical space, assuming the housing capacities are the same. Hope this helps! |
04-18-2021, 10:44 PM | #6 | |
Rep 417
I saved many older manual transmissions using Redline MTL where BMW fluid would have doomed them. I ran non BMW fluid in many BMWs well passed 200k miles. My BMW race car is seeing a huge amount of abuse on non BMW fluid also. I don't buy my parts at the dealer, I sure won't buy my gear fluid and engine oil from them either, but I understand if people think that the dealer knows best.
'16 M4 bone stock
04-19-2021, 01:57 AM | #7 | |
Rep 16
Thanks!
Redline is hard to get around my parts, but i can get my hand on some Liqui Moly oil - that would then be this one, correct? https://products.liqui-moly.com/oils...-75w-90-1.html Thanks! Quote:
04-19-2021, 01:59 AM | #8 | |
Rep 16
Thanks! I totally get the idea of using only the OEM product, just seems like quite a price difference - not totally convinced that it's a better product than whatever else is available.
But I appreciate your input, thanks! Quote:
johnung4531.00 |
04-19-2021, 04:59 AM | #9 | ||
Rep 5,395
I rarely buy anything from a dealer. But I do buy genuine BMW parts when necessary at a discount from retailers like FCP Euro. I'm more concerned that I use the fluid that the engineers who designed the component specified. That's why I use ZF fluid in my ZF designed and manufactured transmission. Sure people use aftermarket fluids with no problem. But there are also horror stories about aftermarket fluids having negative results. IMO I don't see any upside to risking a really expensive transmission, differential, Limited Slip Differential or Transfer Case based on aftermarket fluid marketing claims, or trying to save what is a negligible amount of money compared to the replacement cost of the component that it's protecting. |
04-19-2021, 05:06 AM | #10 | |
Rep 16
Yeah, youre right - its not worth risking the diff og transmission ect. (im getting a transmission oil flush tomorrow at the BMW service (dealer), they will use OEM)
04-19-2021, 10:49 AM | #12 | ||
Rep 5,395
You would probably get a much lower price through a local BMW independent mechanic. The automatic transmission service is a special procedure with a complete replacement of fluid, pan with its built-in filter, and pan bolts. The ZF Service Kit costs under $300. Genuine BMW kit might be 2x that. |
04-20-2021, 05:29 PM | #13 | |
Rep 1,572
Unless you perform a Transmission "Flush" with special equipment you are only removing/replacing about 2/3 of the full capacity. The local dealer and my Independent BMW Master Mech. both Do Not recommend the flush. Potential for damage apparently is significant. At FCP, a BMW Automatic service kit with ZF fluid is $303 and one using Liqui-Moly equivalent is $186 |
04-20-2021, 09:27 PM | #14 | ||
Rep 5,395
07-13-2021, 05:42 PM | #15 | |
Rep 78
Drives: 2014 535i xDrive
I phone redline and they saying 75w90... |
07-13-2021, 06:44 PM | #16 |
Rep 5,457
Drives: F30
bmw oem pn: 83222295532
07-14-2021, 07:47 AM | #17 |
Rep 417
75w90 is good. You can't go wrong with Redline or Liquimoly oil. Or BMW oil if you only believe in dealers.
'16 M4 bone stock
08-04-2021, 01:52 PM | #20 |
Rep 5,457
Drives: F30
