05-15-2021, 05:09 AM | #1 |
Rep 6
118401 mixture control AFR Too lean
Hey guys ,
So recently I decided to go FBO. I had an issue earlier where I didn’t put a o ring on the charge pipe where it meets the throttle body and I was getting low pressure intake manifold. Ordered the o ring and fixed the problem. Car was running great no lag or anything. Eventually popped a Lambda code before cat.. cleared it, never came back. Now I’m my constant code is running to lean. I have an angled spacer on my post cat o2 sensor. I read on another thread that those are crap apparently. I’m looking for advice for other possible reasons as to why I’m running lean and to find other people with n26’s with FBO that have no issues with aftermarket parts. Also I’m new to this group as well |
05-20-2021, 10:01 PM | #2 | |
Rep 50
05-29-2021, 02:49 PM | #3 |
Rep 13
I had the same problem. I have a 328ix drive N26 SULEV.
I replaced my oxygen sensor on my exhaust. After that the problem was solved but I had still a mixture too lean fault code. After research I saw that my car has a extra Oxygen or O2 sensor on my radiator. The sensor did not work any more. So I needed to change the whole radiotor... The sensor had no function so I decided to let the sensor code out the car so the problem is solved now. |
05-29-2021, 09:25 PM | #4 | |
Rep 50
05-30-2021, 02:46 PM | #5 | |
Rep 13
But mixture too lean could be anyhting.. I saw several problems on the same cars with different parts to be changed. |
05-31-2021, 01:12 PM | #6 | ||
Rep 50
