BMW X5
      06-10-2021, 07:23 PM   #1
GBB2
GBB2
Drives: BMW X5 G05
2019 Base Front Brakes
Does anyone know if there are any special requirements to replace the front brake pads (non-M)? i.e. Any special procedures before compressing the piston? TIA
      06-19-2021, 04:30 PM   #2
GBB2
GBB2
Drives: BMW X5 G05
So I ended up ordering the Powerstop Z23 Carbon fiber ceramic (base) front brake pads and installed them today. Pretty much like replacing any other brake pads. Remove caliper/compress pistons & install new pads. I spent more time polishing the rotor hub and cleaning the calipers than actually swapping the pads. After install I did set the parking brake before touching the brake pedal and starting the car. Brakes feel good, much less grabby than the stock pads.... smoother stopping. FYI car had just a little over 27k miles..mostly city driving.
      06-19-2021, 05:00 PM   #3
Gone Fishing
Gone Fishing's Avatar
Drives: BMW X5 xDrive 40i
Thanks for the update, let us know after a few thousand mile how they feel
      07-04-2022, 01:39 PM   #4
johnronin
Drives: F90 and G05
How do you take off the metal brackets holding the pads in the calipers?
      08-29-2022, 04:11 PM   #5
Bking60
Drives: BMW X5 2019
Those are just anti rattle springs. Take a picture first because even though they pop off with some needle nose pliers (safety glasses) they are confusing to get back on sometimes since they go back under spring tension.
xbimmers
