07-20-2021, 09:18 PM | #1 |
Rep 11
Drives: BMW X5 sDrive35i
CEL On with Code P0030 after Catless DP install
Lets see if someone can help me here. Installed a VRSF Catless downpipe yesterday to pair with my bootmod3 tune. Disabled Cat Checking and did a reflash before I did the install.
Got it installed and drove it around for a bit. Sounded great. Awhile later I went on another drive but this time I had a check engine light. Scanned the codes and got a P0030 HO2s heater control circuit Checked the connections and made sure they weren’t flipped, everything checked out. Other than me breaking the sensor, is there something else that could be wrong? |
07-20-2021, 11:08 PM | #2 |
Rep 656
Due to the work you did damaged wiring or damaged sensor are the most likely culprit. Recheck connections for bent pins and look for pinched wiring. Also check continuity of wiring an if your obd reader has the capability, check lambda readings live from the upstream bank 1 sensor.
