BMW M3 and M4 - The Icons
home
Classifieds Sponsors Classifieds Engine / Drivetrain / Exhaust / Bolt-ons
      09-29-2021, 09:30 AM   #1
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
20% OFF INTRO SALE- Evolution Racewerks S58 Competition Catless DPs G80/G82 M3/M4
ORDER LINK
https://www.n54tuning.com/competitio...58-engine.html
Key Features:
Now available for the 2021+ BMW M3/M4 S58 Engines!
Higher Max Horsepower Power Curve
Higher Intial Torque Curve. Torque curve hits faster and higher and longer.
Better throttle response and faster turbo spool up times
Mandrel Bent 3" piping. Smooth transition to the exhaust system.
100% Stainless Steel Construction
100% TIG welded for better quality welds
Precision CNC machined turbocharger V-Band flange
Mirror polish or brush finish
Available with high temperature black thermal coating to reduce underhood temperatures
Compatible with the factory or aftermarket exhaust systems
Track tested durability
Includes all hardware for complete installation
Limited Lifetime Warranty
Full Downpipe Set (Downpipes with optional Crossover Pipe) in Brush Finish
Restrictions in the exhaust system robs horsepower and torque especially on turbocharged cars. Thus, removing as much exhaust flow restrictions will increase horsepower and torque significantly. The factory catalytic converter found in the factory downpipe is a big culprit of this and is a major exhaust flow restriction. The factory catalytic converter is made up of catalyst material formed into "honeycomb" weaves. Exhaust gas must pass through these tiny "honeycomb" weaves on their way to the exhaust system thus causing a major exhaust flow restriction. It also causes turbulence after the catalytic converter which causes the exhaust flow to slow down (which increases restriction). By replacing the factory downpipe/catalytic converter with our Competition Series Catless Downpipe, more power is unleashed! You will feel the difference instantly.
Our Competition Series Catless Downpipes is constructed out of 100% 304 grade stainless steel and utilize mandrel bent piping. They are 100% TIG welded by our in house fabricators and built in the USA. The factory turbocharger turbine housing utilizes a 3.5" V-Band flange which we have duplicated and CNC machined cut out of billet 304 stainless steel. Stainless Steel CNC machined O2 sensor and laser cut brackets are TIG welded using stainless steel rods. The O2 sensor is positioned at the factory location. The factory donut flange design is retained. 100% bolt on.
Our downpipes are designed to fit perfectly with either the factory exhaust system or your aftermarket exhaust system. There are no compatibility issues whatsover. The downpipes will come by default with brushed finish.
OPTIONS
Ceramic Thermal Coating - The purpose of ceramic coating downpipes is to keep heat from the exhaust gases inside the downpipe from radiating out. This keeps underhood temperatures lower and less heat absortion by nearby parts/surfaces. Another added benefit is that by keeping in heat (energy) in the exhaust gases inside the downpipe, exhaust flow velocities stay up, resulting in lower backpressure. The ceramic coating also adds additonal corrosion resistance. We utilize the best ceramic coating possible. Our thermal coating can resist up to 2000F of heat. It is available in black only (all the other colors cannot withstand the high levels of heat).
Midpipe Crossover Pipe - The G80/G82 utilizes a Y style Midpipe. Since both downpipes on are on the right side of the vehicle, the Midpipe Crossover Pipe connects the left side downpipe to the left side of the Y midpipe. The factory crossover pipe goes underneath the transmission and is ovalized for clearance. Our Midpipe Crossover Pipe does not ovalize but retains a round shape for ideal flow conditions.
Scorp!on1511.50
      10-06-2021, 12:59 PM   #2
Mike@N54Tuning.com
Bump @ www.n54tuning.com
Mike
      10-25-2021, 09:07 AM   #3
Mike@N54Tuning.com
Bump for a great deal @ www.n54tuning.com
Lowest Prices on the FORUMS!!
Mike
      11-08-2021, 10:05 AM   #4
Mike@N54Tuning.com
Mike
      11-20-2021, 02:39 PM   #5
Mike@N54Tuning.com
Bump for a Great Deal @ www.n54tuning.com
and as always the LOWEST price Guaranteed!!
Mike
      12-01-2021, 12:48 PM   #6
Mike@N54Tuning.com
Mike
      12-28-2021, 12:10 PM   #7
Mike@N54Tuning.com
Mike
      01-18-2022, 02:55 PM   #8
Mike@N54Tuning.com
Mike
      01-20-2022, 01:40 PM   #9
Mike@N54Tuning.com
Mike
      01-26-2022, 02:00 PM   #10
Mike@N54Tuning.com
Mike
      01-27-2022, 03:20 PM   #11
Mike@N54Tuning.com
Mike
      01-31-2022, 12:30 PM   #12
Mike@N54Tuning.com
Mike
      02-07-2022, 01:27 PM   #13
Mike@N54Tuning.com
Mike
      02-14-2022, 01:57 PM   #14
Mike@N54Tuning.com
Mike
      02-22-2022, 01:09 PM   #15
Mike@N54Tuning.com
Mike
      02-26-2022, 10:21 AM   #16
Mike@N54Tuning.com
Mike
      03-07-2022, 04:05 PM   #17
Mike@N54Tuning.com
Mike
      03-14-2022, 08:46 PM   #18
Mike@N54Tuning.com
Mike
      03-21-2022, 12:14 PM   #19
Mike@N54Tuning.com
Mike
      04-14-2022, 11:38 AM   #20
Mike@N54Tuning.com
Mike
      04-18-2022, 03:43 PM   #21
Mike@N54Tuning.com
Mike
      04-20-2022, 12:31 PM   #22
Mike@N54Tuning.com
Mike
g80
