11-05-2021, 12:24 PM | #1 |
Rep 9
A new rim for F34 calculation
Hi guys, I'm going to upgrade my wheel and I'm trying to put 9" width to the front and 10" width to the back.
Any suggestion please? The rim is preorder so I can't try it first and I have checked with BMW SA but they only have 8" width rim only. Thank you in advance
I AM 3GT
03-19-2022, 09:59 AM | #4 |
Rep 109
I run:
19x8.5 et37 225.45 Front 19x9.5 et33 255.40 Rear Compared to yours: https://willtheyfit.com/index.php?wi...8.5&offset2=29 https://willtheyfit.com/index.php?wi...=10&offset2=42 I am running ACSchnitzer lowering springs: You are running slightly more narrow tires, i think they should work. Since that picture, I have a 5mm spacer up front..so you always have that option if you need more clearance with the front strut |
03-30-2022, 01:43 PM | #5 | |
Rep 22
04-08-2022, 01:44 PM | #8 |
Rep 109
I'll have to see if i made notes when i installed them if i measured before and after. Otherwise, i think they were advertised as 20-25mm and seems like the rear went down a little more than the front (if i had coilovers, i would lower the fronts another 10-15mm.)
04-10-2022, 06:17 PM | #9 | |
Rep 5
Thank you
