12-04-2021, 08:06 AM | #1 |
Rep 131
SOS Call System Failure (PLEASE help!)
Hello everyone. I just got this "SOS Call System Failure" message on the dashboard and headunit. This is scaring me because the car is only 3 years old.
I currently drive a 330i f30, year 2018. The only modifications/tuning I have done was adding an amplifier to the car for the audio system, which has been running fine for the past two months, replacing the stock amp. I feel like this may be the only issue that may have caused this error message? I also have upgraded to an M Performance Exhaust. Highly believe this wouldn't be an issue. I have gone through the error list on BimmerCode if that can be of any help. |
12-04-2021, 08:16 AM | #3 | |
Rep 131
I'm currently out of my warranty phase. How much do you think this would cost bringing it into the dealership? |
12-04-2021, 09:49 AM | #4 |
Rep 262
Backup battery in the roof above rear brake light. Mine just crapped out at 37 months (14000 miles).
Replaced myself. Go to dealer for part…superseded item. You DO need Carly or something else to code off the error message. |
simplyeric78.00 |
12-07-2021, 07:48 AM | #7 |
Rep 2,850
Drives: F33 430 and F39 M35i
see if it's covered by warranty to replace the battery. it needs to be changed or the error coded out.
12-12-2021, 02:01 AM | #9 | |
Rep 131
All you need to do is pop the rear light compartment open above the backseats on the roof. That is where the sos battery compartment is. Becareful when taking it off because you can break the pieces, especially the center clip. Once you pop it off, use a t-25 screw to pop off the two screws and then pull the roof down that is also clipped by two clips. Pull down the roof and you'll see the battery compartment. Replace and then code it out with BimmerLink. |
12-12-2021, 02:02 AM | #10 |
Rep 131
12-12-2021, 11:51 AM | #11 |
Rep 559
Glad it can be coded out. I don't have a problem with mine at the moment but would be good for future reference since my car is a 2014 so it's going to happen sometime.
Does anyone know what needs to be coded via E-Sys to code it out? I assume it's a case of removing 619 from VO but then what modules need to be coded after? Or is it easier to just FDL code the relevant modules? |
12-12-2021, 01:24 PM | #12 | |
Rep 131
I would just invest into BimmerLink w/ a recommended compatible OBD2 adapter so it just saves you all the work of deeper coding. 2014 and no problems w/ the battery so far is going long and strong it seems like. For future reference, the OEM battery product # is 84102447710. I can't believe mine died as I'm on my 3rd year of ownership for my f30. I think they die faster when you are living in cold environments. |
12-12-2021, 04:52 PM | #13 |
Rep 16,671
Bimmerlink is for diagnosis and repair. Bimmercode is for coding. I can't imagine not having Bimmercode. it's worth the price just to get rid of the legal disclaimer every time you start the car.
01-07-2022, 07:52 PM | #15 |
Rep 1,750
Will code out error, not fix it.
Worked for my NBT: KOMBI => ST_ECAL_ALIVE = nicht_aktiv KOMBI => ST_ECAL_TIMEOUT = nicht_aktiv Some also had to add this: HO-word TELD to the VO and code CMB_MEDIA and KOMBI. This is for cars with TCM: TCM_ALIVE_MONITOR -> nicht_aktiv TCM_ID_MONITOR -> nicht_aktiv |
01-08-2022, 12:12 PM | #16 | |
Rep 68
01-08-2022, 09:50 PM | #17 |
Rep 1,750
01-11-2022, 02:01 PM | #19 |
Rep 180
My SOS issue is driving me crazy! Over the last few months, I've been having trouble accessing any of the connected services (Update BMW Assist grayed out)from the car. Sometimes it works, sometimes it doesn't. It will magically start working after I've been driving for about 30 minutes. When it doesn't, I get a SOS malfunction for about 3 seconds once per engine cycle, as if it's the low temperature warning, usually within 10-20 minutes.
When I scan, the only error that seems to be related is E14600. I've removed the ATM a few times now to make sure everything is plugged in properly. The ATM was replaced by the dealer with the upgraded 4G module back in May. The messages did not start until about 5 months after it was replaced. I've replaced the battery in the ATM just in case, but it had no impact. Any idea why my car connected sometimes and not others? |
01-11-2022, 02:04 PM | #20 | |
Rep 131
Removed the battery from the compartment located under the shark antenna (Youtube). Replaced the battery and coded it out via BimmerLink. It was that simple. No issues whatsoever on the SoS message! Also if you are living in colder climates like I do, the battery does seem to die faster apparently. |
02-01-2022, 01:31 AM | #21 |
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
If 3G Cellular is being sunset in your part of the world, many BMW Connected Drive features will stop working for cars with 3G Modems (pre-2016ish). It may cause the SOS Malfunction. Magic date in the US is February 2022. Mine popped up on 1/31/2022. Some cars can be upgraded with 4G HW and some can't...BMW should have figured out a custom workaround with a new telematics 4G unit.
I had my roof wrapped in CF vinyl, and the shark fin wasn't sealed. So there were leaks when going through laser car washes through the antenna and the third brake light. BMW put the telematics module under the shark fin (sometimes it was mounted in the trunk). Stooooopid. Water damage might effect all your calling and bluetooth features. Telematics unit is $600, but it has to be coded to the VIN. Another antenna module is under the shark fin. A rechargeable Li-Ion backup battery is also installed in the telematics unit that can be replaced easily ($90). My battery is 7 years old. I think if you read the codes, it will indicate if the battery is past its expected life, as if it is tracking the battery expiration date. Cheers |
04-10-2022, 02:14 PM | #22 | |
Rep 313
sos |
