04-13-2022, 11:44 AM | #23 |
Rep 249
I'm stuck at work at this moment but I'm sure there was a post somewhere on x5 f15/f16 have a search there, some newer vehicles had this coding option removed but I don't want to give you false info, if you can't find it once I get back home I will have a look.
Abzynthe1387.50 |
04-13-2022, 12:30 PM | #24 |
Rep 2,127
I found this. I'll give it a go
https://www.bimmerpost.com/forums/sh...php?p=27260212 https://www.bimmerpost.com/forums/sh...php?p=27429216
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
ade555115.00 |
04-13-2022, 10:42 PM | #25 | |
Rep 249
04-14-2022, 04:17 AM | #26 |
Rep 2,127
It works
ade555115.00 benny_carpz0.00 |
04-14-2022, 10:45 AM | #27 |
Rep 249
04-14-2022, 01:13 PM | #28 |
Rep 2,127
Yeah it's way better now.
I think when it initially starts moving it goes to go fast but slows down after less than a second.
04-14-2022, 02:24 PM | #29 |
Rep 249
So what values have you put in your coding? Looking at the post on x5 forum you can enter individual speeds for 6 different tailgate position?, might be worth playing with figures so it comes down faster till gets somewhere near latch, if you happy with result leave it as it is.
04-14-2022, 02:26 PM | #30 |
Rep 2,127
Yeah I will have a play around with it, but I followed the post where is says change node 1 and 2 and someone said they used value 0A for both, so that's what I did.
04-14-2022, 02:55 PM | #31 |
Rep 249
hmm I wonder if Node 1 is responsible for speed near the latch or Node 2, because when you look at the coding of pre 2017 normally the numbers are ascending example byte 1 = 20 byte 2= 30 ect., so if you went with lower number at Node 1 and higher number Node 2 you might have a faster closing speed then slowing down just before it laches, as you went for same value to my understanding this mean same speed all the way
04-15-2022, 12:13 PM | #32 |
Rep 2,127
I changed node 2 up 2 values and it's a bit quicker to close in the mid section. I think it's about 1second quicker overall. I'm happy with that
ade555115.00 |
04-16-2022, 05:33 AM | #33 | |
Rep 12
Where did you find the parameters to change? I have an f36 2017 lci and I can fin only numbers instead of folder names. I want to code via Esys Thank you very much! |
04-16-2022, 09:53 AM | #34 | ||
Rep 2,127
04-16-2022, 01:25 PM | #35 |
Rep 2,127
On a side note, I had to speed up node 1 to the next setting as it wasn't latching properly.
05-29-2022, 03:21 PM | #37 | |
Rep 833
Drives: BMW F36, E36, E93
Thank you
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
02-10-2023, 06:59 PM | #38 | ||
Rep 134
Tailgate Function Module > 3011 APPL_PLG_SPEED_PROFILE
'16 BMW 440i GC AT | '17 LCI BMW M240i AT | '94 Mazda MX5 | '04 BMW M3 E46 6MT | '07 Seat Lean FR 2.0 | '01 Seat Ibiza Sport 1.6 | '94 Nissan Sunny LX 1.4 |
04-16-2023, 07:34 AM | #39 | |
Rep 6
turn on Expert mode, and then change: 3011 APPL_PLG_SPEED_PROFILE > ProfileCloseStopNode1PwmPIg > wert00A0 3011 APPL_PLG_SPEED_PROFILE > ProfileCloseStopNode2PwmPIg > wert010E Tested on F36 LCI 2017 ✌️ |
07-11-2023, 03:08 AM | #40 |
Rep 22
Hi guys
I am coding with e-sys my car is 2015 F36. But I do not know what values to use for softer closing tailgate. Module - HKFM Folder - DREHZ_SEGMENT_SCHL As seen in bimmercoding app- I assume it is right place for e-sys also. So I choose ausgelesen folder there. I see there multiple values rr05,rr04,f36 etc. When I choose only f36 it shows werte is 4C, and it repeats 9 times What values should I put in there to get it working? I also tried rr06, f01 settings but nothing changed. Thanks!!! UPDATE! SOLUTION: i used code 0C, 0C, 1C, 2C, 4C, 4C, 4C, 4C, 4C And its now much better. For some maybe too slow but good for me. Last edited by HarryMrn; 07-11-2023 at 07:46 AM.. |
