BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 120408 121533 Error Codes (Charging Pressure Control, Charging pressure ambient)
      12-28-2021, 06:48 PM   #1
socalengineer
Drives: 640i F13 Alpine White
Hi,
I'm getting two codes on my 2015 N55 PWG engine:
120408 - Charging pressure control: Switch-off as consequential reaction
121533 - Charging pressure - ambient pressure, comparison: Charging pressure too low.
- DME shadow (inactive) codes:
121521 - Boost pressure sensor. Multiple fault.
1F2801 - DME 2, Software: Program invalid.
1F2802 - DME 2, Software: Data invalid.
I just had the valve cover changed. The car is not going into boost either, it goes really slow. I also get a drivetrain malfunction sometimes.
Also I just put a new map on with bootmod3, and changed the boost sensor to the N20 3.5 bar sensor.
Please advise did I do something with the N20 sensor? Or is it something the mechanic might have done with the Valve cover? Thank you
      12-28-2021, 08:16 PM   #2
socalengineer
Nevermind... was a user error. Chose the intake manifold TMAP, instead of the pre-throttle TMAP option in bootmod3. Car runs fine now.
