E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Is There Any Way To Easily Adjust E92 Door Tweeter Positioning??
Reply
      12-02-2008, 04:52 PM   #1
TwnTrboCAT1212
The Moose Whisperer
TwnTrboCAT1212's Avatar
Drives: '08 E92 GIAC S1 335xi 6-MT
Question Is There Any Way To Easily Adjust E92 Door Tweeter Positioning??
Yes, you are all probably wondering what the hell is this kid talking about?...But when someone like me has bad OCD and every little imperfection bothers them and wants it to be fixed if possible (especially if its something with their new 335 Xi coupe), any help would be appreciated to satisfy the needs. Probably some of you with coupes have noticed that the tweeters are somewhat poorly fitted in the corner of the door between the weather stripping and the door panel and while not very noticeable, there Are gaps between the tweeter unit and the upper part of the door panel. In my situation, the passenger door tweeter unit is almost perfectly flush against the door and flows smoothly with the side of the door panels when the door is opened. The driver's side tweeter on the other hand seems kind of loosely attached to whatever its attached to and when the door is open, it sticks out a bit on the side of the door panel and is not as flush as the other side unit (causing a bigger gap underneath the unit and not allowing for it to sit flush). While I know it may not seem to be a big deal and that the beautiful sounds that come out of the speaker will not be compromised by being like this, I still must look at this imperfection every day and I would really like to know if there is a simple adjustment that can be made to make it sit appropriately and more tight against the door panel as the passenger side is. I really would like to avoid removing the entire door panel to do so, but if anyone has feedback or advice regarding my "issue" haha....Please let me know. Thanks,
~ Chris ~
      12-03-2008, 03:08 AM   #2
MOB
MOB's Avatar
England
56
Drives: Alpine White M2 LCI
Have you tried moving it around with your hand? It is held on by a clip and a plastic lug that slides into a recess in the door.
Otherwise you would have to remove it and refit it - there are no screws, it just pushes on
You do have to remove the door card, but thats a simple job
Reply
e90post
