04-19-2022, 01:43 PM | #1 |
Melbourne Red F32 B58
59
Rep 99
MHD Map Switching
I have seen how easy it is to switch from map to map on the fly.
My question is actually regarding the "power level in percent per map slot" https://mhdtuning.com/collections/mh...icense-for-b58 Is the percent from the total power, or the gained power? Example: 470hp @ 80% = 384hp | Or is it an estimated gain of 150hp @ 80% = 120hp gain Has anyone used this and how do you like it? My thought process is to use the percent of the full tune because I dont think I need or want the full gain. Stock clutch slipping and other little things pop up when Stage 2 is in use that I would like to stay away from. This is all near future plans at this point. FBO with MHD happening in the next month.
Real drivers use 3 pedals. Its about connection.
04-19-2022, 01:55 PM | #2 | |
Rep 1,010
All those percentages are rough figures, best way is to try them and decide which suits your needs but I can assure you the lowest percentage is really slow.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
BeFitty8_F3259.00 |
04-19-2022, 02:26 PM | #3 |
Rep 171
My guess would be that it it's more of a "variation VS stock parameter" ratio rather than a power output ratio. Let's take a silly example : say stock timing is 5 degrees and stage 2 timing is 15 degrees. Then 60% of stage 2 would be 11 degrees of timing (namely 5 from stock + 60% of the extra 10 degrees brought by stage 2).
And same logic goes for boost. It's just my guess though, someone from MHD would have to confirm or infirm. |
BeFitty8_F3259.00 |
