BMW M3 and M4 - The Icons
home
G80 BMW M3 and M4 General Topics Regional Forums CANADA
      05-13-2022, 10:14 PM   #1
Forzanerazzurri
Drives: E46 M3 Coupe/G80 M3CX
50th Anniversary Badges
Dealer just notified me that my individual order from Dec is finally going into production in June. I inquired about the 50th Anniversary Badges and they told me that in Canada it's a $300 option. Anyone else have any info on this?
Limegrntaln13473.50
      05-13-2022, 10:32 PM   #2
Limegrntaln
Limegrntaln's Avatar
Drives: 2022 DG/BLk xDrive M4C Wk 34
Not according to your ordering site. Make sure you make changes to your order before 150 status.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou
      05-13-2022, 10:38 PM   #3
Forzanerazzurri
That's what I thought. Thanks!
Limegrntaln13473.50
      05-14-2022, 05:53 PM   #4
nyc_dude
nyc_dude's Avatar
Drives: 09 //M3 e90 Interlagos Blue
In general, the 50th Anniversary Classic M emblems became available after March 2022 on ///M cars and ///M Performance car. They were added by default, unless you declined. Not sure if that means orders placed after March 2022 or production starting after March 2022.
Check with your BMW dealer...based on your build sheet. Either way, if your baby arrives without them, the dealer will make it right, since they should have a bucket load of these 50th Anniversary Emblems which are in high demand.
You can go on the BMW Configurator and see if they they look good with your exteriors paint and wheel finish. You might have to mix and match. There are also floating wheel center cap options to retrofit.
Cheers
      05-14-2022, 08:47 PM   #5
Forzanerazzurri
Cheers
Great info. Thanks for this.
      05-14-2022, 11:49 PM   #6
Dual.V8
Drives: m5 f90
  [0.00]
Cheers
My car was build on week 11 ( march 14) and I don't have them
F90
      05-15-2022, 02:30 AM   #7
Limegrntaln
Not all countries are the same. In Canada, you have to select it for the build, yourself. The US cars, you have to check the box to remove them, because they are standard. If you haven't entered into 150 status, you should be able to modify your order. Read post #2, above, in Canada you have to select it, yourself.
YT: G Dubyou
      05-15-2022, 08:43 AM   #8
rush111
rush111's Avatar
Drives: 2022 G82X individual
2022 G82 M4 Competi ...  [9.81]
2016 X1  [0.00]
Cheers
Same here. Looks like you had to request them in Canada vs. being standard in the U.S. for March production anyway (in spite of mine being an individual color).
      05-15-2022, 10:33 AM   #9
nyc_dude
nyc_dude's Avatar
Rush111 - Check out the Rush Moving Pictures 40th Anniversary Super Deluxe Album for $300 -- weigh 20 lbs with drumsticks, books, Vinyl, and a Red Barchetta. Ridiculousness.
You can always add the 50th Anniversary Roundels or your dealer can swap them out. Available to order the parts in June 2022.
Cheers
      05-15-2022, 11:03 AM   #10
AlbertZ
AlbertZ's Avatar
Drives: G80 M3
[IMG][/IMG]
As far as I know, they should be free. Here is my friends M4
      05-17-2022, 08:01 PM   #11
Forzanerazzurri
Just went to status 112 (individual order) and they say it's locked in so I'll have to get the badges after. No big deal.
      05-17-2022, 09:41 PM   #12
Osheatwo
Drives: BMW M3 Comp Xdrive
2021 BMW X5 M50i  [10.00]
2023 BMW 330E  [10.00]
You can order from here: https://paddleshifterz.com/product/b...v=7516fd43adaa
Just received mines today
      05-17-2022, 10:11 PM   #13
Forzanerazzurri
Thank you! I will try to get my dealer to throw them in. I told them i wanted to go over the build sheet before it was locked down and they kind of forgot about me
      05-19-2022, 10:15 PM   #14
Forzanerazzurri
Does anyone know if the front and rear roundels on the g80 m3 includes adhesive on the back or is it just like most models where it just pops off the grommets?
      05-20-2022, 05:07 PM   #15
nyc_dude
nyc_dude's Avatar
Congrats First in the US.
Would you post the P/N photo on the box? You can see that the rear roundel has a hole at the bottom for a rear sensor. Most folks won't want to order that version.
IND has the 50th Anniversary wheel center caps, but wait a few weeks to get a better price. They are probably only for certain models like the G8X M3/M4. There are 3 or more sizes for different model platforms.
Cheers
      05-20-2022, 07:47 PM   #16
Osheatwo
Cheers
I actually got a decent price for them and they arrived in less than 10 days from order to received.
These P/N are for the M4 G82
front: 51 11 7 886 545
Rear: 51 14 8 087 199
Tire Center: 36 12 5 A57 484
Just install today
      05-20-2022, 08:03 PM   #17
Forzanerazzurri
Just install today
Did the old ones pop off or were there adhesives on the back
      05-20-2022, 09:00 PM   #18
Osheatwo
Just install today
There is adhesive on the back. Double the amount on back versus front. Used fishline thread to get underneath the emblem to separate the glue.
Once it separated, used trim tool to pop them right off.
Cleaned off residue and pushed new ones on.
      05-20-2022, 09:16 PM   #19
Forzanerazzurri
Dammit
      05-21-2022, 01:50 PM   #20
nyc_dude
nyc_dude's Avatar
Well done. Looks fantastic.
For others...
- Pick up a replacement set of grommets for older cars.
- Many BMW Roundels use an adhesive now, so the removal might require a heat gun/blow dryer. $%#%^$# BMW
- The front hood emblem P/N should be universal (82mm).
- The rear trunk emblem P/N will change depending on model and options (74mm). Some SAV rears are the same size as the hood roundel.
- The wheel center caps are different sizes for different models.
- The wheel center caps should come in a non-floating standard and floating versions. If you have to spend extra money, might as well go floating center caps.
Hopefully, they will hit the US market after next week in June, after the Memorial Day Holiday weekend.
Cheers
      05-21-2022, 02:06 PM   #21
MBM340
MBM340's Avatar
Drives: 2021 M340 RWD
2021 BMW M340i  [0.00]
I just ordered
The hood and trunk ones from BMW Parts Pros. I have a mineral white metallic M340. From the pics I have seen these look fantastic.
"Either get busy living, or get busy dying. That's GD right." - Red (Shawshank)
      05-21-2022, 02:42 PM   #22
nyc_dude
nyc_dude's Avatar
BMW 50th Anniversary Classic M Roundel P/N Decoder Ring Table.
The BMW 50th Anniversary Classic M wheel center caps are probably only available for G8x M3/M4 wheels and other similar models with a single p/n for the non-floating set.
There are different p/n's for older F/E model BMWs. A separate set of p/ns for floating center caps for different wheel hub diameters.
Cheers
g80
