05-16-2022, 12:59 PM | #1 |
Rep 115,980
N54Tuning.com - BMS Billet Exhaust Tips For 2021+ BMW G80 M3 & G82 G83 M4 (Set Of 4)
ORDER LINK
https://www.n54tuning.com/bms-billet...-set-of-4.html Upgrade Your G8x Factory M Exhaust Tips To Larger BMS Billet Custom Tips The BMS angle cut billet 4.5" exhaust tips are the perfect choice for dressing up your factory M exhaust outlets. 27% bigger than stock these unique billet tips are sure to turn heads. Our tips are equipped with set screws so they go on easily and stay in place. Available in ceramic matte black and polished Silver Billet. The ultimate exhaust finish ceramic coating can withstand extreme temperatures up to 1200 degrees and provides a durable and great looking finish that rivals OEM quality and longevity. Made in the USA. Not for use with M-Performance exhaust systems or X3m/X4M. S58 G8x Exhaust Tips Applications BMW M3 • 2021+ S58 G80 BMW M3 • 2021+ S58 G80 BMW M3 Competition BMW M4 • 2021+ S58 G82 BMW M4 • 2021+ S58 G82 BMW M4 Competition Available in 2 styles. Sold in sets of 4. • Angle Cut Ceramic Matte Black • Angle Cut Polished Silver Billet What's included: (4) BMS 4.5" Exhaust Tips (8) Allen key threaded set screws To install remove your factory tips by pounding outward on the lower rear part of the tip with a screwdriver/chisel and either a rubber mallet or a hammer. This is done from under the rear of the car. Small to medium taps will start the factory tip sliding off the actual exhaust pipe. You can spray some lubricant in there to make it easier if needed. Slide the BMS slip-on exhaust tip straight over the factory exhaust pipe and tighten the set screws. We recommend using some blue thread locker. Note the slots on the BMS tips are for visual alignment purposes only. They will not completely engage with the factory dowels on the factory pipes. |
05-18-2022, 06:41 PM | #2 |
Rep 115,980
05-23-2022, 05:19 PM | #3 |
Rep 115,980
05-27-2022, 09:49 AM | #4 |
Rep 115,980
06-06-2022, 04:21 PM | #5 |
Rep 115,980
06-09-2022, 10:11 AM | #6 |
Rep 115,980
06-15-2022, 11:50 AM | #7 |
Rep 115,980
06-26-2022, 09:12 AM | #8 |
Rep 115,980
07-07-2022, 11:19 AM | #9 |
Rep 115,980
07-26-2022, 11:00 AM | #10 |
Rep 115,980
08-04-2022, 10:19 AM | #11 |
Rep 115,980
08-17-2022, 12:22 PM | #12 |
Rep 115,980
08-24-2022, 06:16 PM | #13 |
Rep 115,980
09-10-2022, 01:40 PM | #14 |
Rep 115,980
10-12-2022, 01:37 PM | #15 |
Rep 115,980
10-19-2022, 04:53 PM | #16 |
Rep 115,980
10-28-2022, 09:04 PM | #17 |
Rep 115,980
11-08-2022, 12:20 PM | #18 |
Rep 115,980
01-22-2023, 02:40 PM | #19 |
Rep 115,980
02-03-2023, 10:22 AM | #20 |
Rep 115,980
03-08-2023, 07:41 AM | #21 |
Rep 115,980
05-24-2023, 10:19 AM | #22 |
Rep 115,980
