BMW M3 and M4 - The Icons
home
Classifieds Sponsors Classifieds Engine / Drivetrain / Exhaust / Bolt-ons
      05-16-2022, 01:00 PM   #1
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
N54TUNING.com - Eventuri BMW G8X M3 / M4 Black Carbon Intake System - Gloss
ORDER LINK
https://www.n54tuning.com/eventuri-b...tem-gloss.html
Performance Gain: 13-18hp, 12-16ft-lb (Stock Tune)
Turbo Inlet Area Increased up to 160%
Filtration Area Increased up to 40%
Presenting an intake which truly sets a benchmark for the BMW G8X M3/M4 platform. We have carried out intensive R&D to develop an intake which not only improves on the stock M3/M4 but also is future proof in its capacity to cater for high powered builds well in excess of 1000hp. Our system is a complete redesign from the airboxes to the turbo inlets with the aim of reducing pressure loss while increasing the flow rate and keeping inlet temperatures low. We have maximized the usage of the available space to employ 2 custom made filters with a 40% larger filtration area than stock. These are used in our Patented Venturi housings to smoothly funnel the air to the turbo inlets. The inlets themselves are up to 160% larger in cross sectional area than stock and are designed with an advanced dimpled inner surface to reduce frictional losses between the flow and the wall boundary. By allowing a “cushion” of air at the wall surface, airflow is able to move through the inlets at higher flow rates with reduced pressure loss. This allows the turbos to draw air with less resistance and therefore reduce the wastegate duty cycle resulting in higher overall performance.
Installation Guide
The Eventuri G8X M3/M4 intake system consists of a number of components engineered to perform a specific purpose and fabricated to the highest of standards. We use 100% pre-preg carbon fiber with no fiberglass which means we can achieve a smooth internal surface to maintain smoother airflow.
Each intake system consists of:
2 x Carbon Fiber Patented Venturi Filter Housings
2 x Bespoke High Flow Dry Cone Filters
2 x Carbon Fiber Inlet Ducts
Carbon Fiber Intake Tube
2 Thermoplastic Turbo Inlets
Laser Cut Stainless Steel Brackets
Custom Flexible Hose
CNC Machined Bracket Mounts and Reinforcement Rings
      05-18-2022, 06:39 PM   #2
Mike@N54Tuning.com
Bump for a Great Deal @ www.n54tuning.com
and as always the LOWEST price Guaranteed!!
Mike
      05-23-2022, 05:15 PM   #3
Mike@N54Tuning.com
Mike
      05-26-2022, 08:24 AM   #4
Mike@N54Tuning.com
Mike
      06-01-2022, 10:36 AM   #5
Mike@N54Tuning.com
Mike
      06-07-2022, 08:48 AM   #6
Mike@N54Tuning.com
Mike
      06-12-2022, 04:30 PM   #7
Mike@N54Tuning.com
Mike
      06-15-2022, 01:50 PM   #8
Mike@N54Tuning.com
Mike
      06-26-2022, 09:58 AM   #9
Mike@N54Tuning.com
Mike
      07-07-2022, 11:20 AM   #10
Mike@N54Tuning.com
Mike
      07-26-2022, 11:45 AM   #11
Mike@N54Tuning.com
Mike
      08-04-2022, 10:30 AM   #12
Mike@N54Tuning.com
Mike
      08-14-2022, 08:09 PM   #13
Mike@N54Tuning.com
Mike
      08-20-2022, 08:17 AM   #14
Mike@N54Tuning.com
Mike
      09-05-2022, 04:30 PM   #15
Mike@N54Tuning.com
Mike
      09-14-2022, 01:33 PM   #16
Mike@N54Tuning.com
Mike
      09-26-2022, 10:28 AM   #17
Mike@N54Tuning.com
Mike
      10-02-2022, 07:44 AM   #18
Mike@N54Tuning.com
Mike
      10-16-2022, 04:31 PM   #19
Mike@N54Tuning.com
Mike
      01-19-2023, 09:38 AM   #20
Mike@N54Tuning.com
Mike
      02-13-2023, 04:02 PM   #21
Mike@N54Tuning.com
Mike
      04-24-2023, 02:15 PM   #22
Mike@N54Tuning.com
Mike
g80
