05-18-2022, 06:50 AM | #1 |
Rep 17
N47 HPFP codes/ WATER CONTAMINATED DIESEL
Hey all just had an issue yesterday with my car which I believe may be leading to the fuel pump or contaminated diesel(hoping not) but wanted some verification before moving forward.
Was on my street about 100 yards from my house on my car died and just stopped in the middle of the street, ended up pushing in parking and when I was able to go back and use Beamer link to scan the codes this is what popped up. I have the extended 120K mile warrannty(currently at 116,000 miles), But I know the HPFP for the N47 Is eligible for replacement under certain VIN’s(did a quick Vin check for my car and it didn’t pop up) Car is currently parked and will be towed to the dealer sometime today and hopefully I can hear back Edit: cant upload picture from but here are the codes: 247500-rail pressure plausabillity 271C00-rail pressure control valve 241200-injection quantity monitoring 2C1E00-over the permissable range 280DD-nox sensor infront of denox kat nox signal invalid for too long 248900-rail pressure low Last edited by NotoriouswithaG; 05-23-2022 at 11:30 AM.. |
05-18-2022, 11:04 AM | #2 |
Rep 1,855
Nearly all of the time HPFP failure starts with fuel contamination of some sort. Minor contamination will allow the HPFP to survive a little, heavier contamination will be quicker.
Your codes are quite specific for HPFP issues, but it can also be an odd LPFP issue. |
05-18-2022, 12:36 PM | #3 | |
Rep 17
Starting to think it’s also just bad diesel |
05-18-2022, 10:16 PM | #5 | |
Rep 17
Ive been seeing more about the bad gas/shady gas stations |
ssf55648.00 |
05-19-2022, 11:57 AM | #6 |
Rep 17
Update: the dealer called and said the fuel pump module went bad. I asked if thats covered under the extended warranty for the fuel pump(im still within the 120k miles range)
Edit: the tech said the both the low pressure fuel pump and high pressure arent getting gas. Would everything be covered u der the extended warranty or am I SOl out of the low pressure scenario? |
05-20-2022, 12:00 AM | #7 |
Rep 1,855
If true, then this is a good scenario. It's unusual though.
The module isn't expensive used, but it can be a few hundred new. It's used across a large range of BMWs, so it's easy to find. One such example https://www.ebay.com/itm/144474365324
05-20-2022, 09:18 AM | #8 | |
Rep 17
Once i hear back by monday ill update |
05-20-2022, 09:39 AM | #9 |
Rep 1,855
Replacement is their diagnostic tactic??
That can get expensive quickly. Did they pull the metering unit in the HPFP to inspect for corrosion/water/signs of damage? That would be a quick and free diagnostic test. |
05-20-2022, 10:31 AM | #10 |
Rep 17
I asked if the diesel had any contamination in it and if the module itself was corroded and tech said no
Hopefully ill know more by later today because im not trying to get this to add up quickly |
05-20-2022, 10:50 AM | #11 |
Rep 1,855
I don't mean the module. The fuel pump control module is most likely fine, despite what they say.
I mean the HPFP. Did they pull the control solenoid off to see inside. That is quite specific. But then again, I guess an LPFP can die. Maybe they have more details. I've met some good techs, and some really bad ones. |
05-20-2022, 03:09 PM | #13 | |
Dr Drei
71
Rep 245
Trust me, I've had this happen and while you can sometimes get your insurance company involved, it it still expensive and time-consuming. Go grab a sample from the tank, have the tech show you the report they got from the lab that shows what the fuel is contaminated with; don't just buy their word. My stomach is knotted for you... Good luck.
GLK 250 // 126xxx miles // 36 MPG // Mobil1 ESP 5w30
05-20-2022, 05:49 PM | #14 | |
Rep 17
Forgot to mention: the tech did the styrofoam cup test and it wasnt eaten up, he showed me and i took pictures, but will still be sending out the sample i got For testing Last edited by NotoriouswithaG; 05-20-2022 at 09:11 PM.. |
05-23-2022, 08:57 AM | #15 |
Rep 17
Another update:
Talked to the shop foreman at my dealer and he said that theres metal in the volume control valve in the HPFP . Their putting the new LPFP in and talking to BMW engineering but I told him my car still is eligible for the HPFP warranty extension because im inside the 120k mile range |
