BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Initializing Headlamps Issue
      09-25-2022, 02:34 PM   #1
PowerF30
Drives: BMW 328i 2014
Angry Initializing Headlamps Issue
Hi, one of my headlight modules were damaged recently and I replaced it with a new one. I reset the FEM with ESYS and the headlight turned on. Thought everything was good until I realized that I got a error “Adaptive Headlight Malfunction” and “Headlamp vertical aim control Malfunction”. Halos we’re on but the adaptive feature wasn’t. I read online that Initialization is needed. So I downloaded Ista, set it up via ethernet and tried to initialize. It says initialization successful the second i click initialize but i still have the error. So I tried initializing with a AUTEL device and im getting the same problem. It initialzes successfully instantly but it doesn’t really go through any initializing steps. I am so lost and am fairly new to programming/coding and have been stumped for the past couple of days. I’ve searched loads of forums for a fix but can’t figure it out. If anyone knows the solution to this or if I’m doing something wrong please let me know. Willing to tip $ if someone is able to resolve this problem. Been a huge headache. Thank you!
      09-25-2022, 02:36 PM   #2
PowerF30
If anyone is wondering I am getting error codes 8041B6 (LWR Faulty) , 8041BA (AHL system Faulty) and 8041FO (Right headlight driver module (TMS): Coding error)Name:  E605A1A6-C9CC-406A-AEE8-D640C2219A84.jpg
i don’t know if the unexpected LIN slave has anything to do with it but let me know
      09-25-2022, 11:31 PM   #3
TheNine90
Drives: bmw
Did you code the new TMS module?
      09-26-2022, 04:51 PM   #4
PowerF30
I used ESYS and I just coded the FEM. I couldn't seem to find the TMS module.
      09-28-2022, 03:51 AM   #5
PowerF30
Does anyone think it’s not initializing because i’m using enet connection instead of ICOM?
      09-28-2022, 01:17 PM   #6
TheNine90
Drives: bmw
It doesnt matter what cable you are using. You replaced the module only? Was it the right or left?
      10-02-2022, 09:32 PM   #7
PowerF30
I only replaced the left module
      10-04-2022, 01:54 AM   #8
TheNine90
Drives: bmw
PM me I can try to help over teamviewer.
      05-23-2024, 01:57 PM   #9
Cartech01
Drives: 335i
Where you able to fix it finally?
