10-06-2022, 09:03 AM | #1 |
Rep 52
[NBT EVO/NBT2]can't read fcs code from neither esys nor SW ID reader
Hey guys,
I've struggled for a few days reading FSC from my f30. (2016 340i in australia). tried SW ID reader(DE) also tried cic. It got 0 byte. Then I tried esys with psdzdata 4.32.12. It got this error. also tried 0xDE, got same error. can anyone please help me out? there are two f020 versions, I tried both but got same results. Thanks! Last edited by bimmerhw; 10-08-2022 at 07:40 AM.. Reason: add nbt2 tag so more people got same problem can refer |
10-07-2022, 03:03 AM | #3 | |
Rep 52
I am trying to read FSC. |
10-07-2022, 05:14 AM | #4 |
Coding ECU's remotely
449
Rep 1,182
For a start, there is no 1B cert in an NBT Headunit.
The problem is that you have NBT2 headunit - it says it there on Esys in the Base Variant field. Given that case, and the year of your car, you can generate a map update FSC code if the headunit is ID4 (list menu only, not tiles). Run the same job in esys but use: 0xF0 - zeroXFzero in the application number - if the unit is ID4 it will pull the FSC, send it to me and I will generate a code for you. if you have ID5 then you have 2 options, buy a map update form BMW or install a set of fake FSC codes with lifetime map updates via USB. EDIT - looked up your VIN, you deffo have ID4 NBT. Last edited by Wibbles; 10-07-2022 at 05:36 AM.. |
10-07-2022, 07:20 PM | #5 | ||
Rep 52
Thank you! it finally works making a small move. I can then see this when click edit button next to <save>. not sure my decode steps are correct? Loading the fsc file seems not working, it got an error: then I copied the serial number(not sure it is a sn though..) at least no errors. I got this file below when I copied the sn instead into the box but it looks garbled in UFT-8 BOM. I tried a few other encodes, no luck. I think I can't upload files other than images, so copied the sn, is this helpful? Quote:
10-08-2022, 03:31 AM | #6 | |
449
Rep 1,182
Save the F0 FSC from your car to your desktop - upload to Mega or Dropbox then PM me the link, I'll do the rest - no charge. |
10-08-2022, 04:57 AM | #7 | |
Rep 52
I've upload to this link: https://mega.nz/file/E9FQHZyR#ynYd_4...TWOJMMSGtMjZB8 please try if it works. btw, I still wonder why I can't use that <FSC generator> tool. why I see other people do it so easy, lol (also saw another way is a usb tool which generate fsc file automatically once you start the car. it doesn't work for mine neither ) Is that my model special? or too old firmware If I wanna diy that, how should I do it? Much appreciated! |
10-08-2022, 05:22 AM | #8 | |
449
Rep 1,182
The reason none of those tools work is because they are not for your headunit, they are either for CIC or earlier versions of NBT, not NBT2 which is what you have. You can only DIY if you have some very expensive software, which I have. There are no tools you can download for free from the internet that will generate the right code for your headunit. Last edited by Wibbles; 10-08-2022 at 05:28 AM.. |
bimmerhw14.00 |
10-08-2022, 06:13 AM | #9 | |
Rep 52
I am actually also working on retrofit my SLI(8TH=SPEED LIMIT INFO), the map is for SLI too.(offline speed limit info when KAFAS not capturing, I can see I have the hardware camera based on some youtube tutorials, they says I only need activate it in ecu.) In that case, do I need a combined fsc to make them both work? [Updated] Thanks man! Thanks to your FSC code, I've successfully updated my maps to latest version. Last edited by bimmerhw; 10-08-2022 at 07:30 AM.. Reason: update progress |
Wibbles449.00 |
10-08-2022, 08:52 AM | #10 |
449
Rep 1,182
You need a 7E FSC code to activate SLI - I can supply for you or you can buy from a main dealer and activate yourself or I can do it remotely.
It's a 10 minute job - are you sure you have the Connected Drive camera in the windscreen? |
bimmerhw14.00 |
10-08-2022, 09:03 AM | #11 | |
Rep 52
I've just managed coding to make it presents in instrument cluster and HUD. It's too late so I didn't start the engine. Not sure whether it works, but I guess not. since it's saying certa are not accepted. I googled and saw that dealer won't sell it as a standalone one. May I ask how much it would cost if I buy one from you? Thanks a lot!! |
10-08-2022, 09:52 AM | #12 | |
449
Rep 1,182
07-30-2023, 09:50 AM | #13 | |
Rep 6
entrynav
i want to update to this map Road_Map_EUROPE_WEST_Route_2023-2 Road_Map_EUROPE_EAST_Route_2023-2 i got the FSC file, can you generate a code also for entrynav? |
07-30-2023, 12:31 PM | #14 | |
449
Rep 1,182
yes I can
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
08-11-2023, 03:14 AM | #16 |
449
Rep 1,182
kdwor0.00 |
08-13-2023, 02:16 AM | #18 |
449
Rep 1,182
I know, but busy with family and weekending
I'll get back to you today.
09-09-2023, 06:16 PM | #20 |
Rep 9
g30 fsc code map
bro i have repair fsc pack, i just need code for my g30 navi update can you generate fsc code for me . if you can i try to send you pm
09-21-2023, 08:40 AM | #21 |
Rep 2,047
11-14-2023, 02:37 AM | #22 | |
Rep 24
matter of fact... i do i screw up my damn gps NA 340i f30 2017 NBT2 if needed =) Last edited by Xxblinddzxx; 11-14-2023 at 02:53 AM.. |
bimmercode, ecu, esys, esysx, fsc, fsc code |
