BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Limited slip or open diff better in the snow for a RWD car?
      11-01-2022, 12:43 PM   #1
AllaVodka
Drives: BMW B58
All things equal. Assume good snow tires.
I've read conflicting anecdotes about the LSD in snow / slippery conditions and figured I would ask the gang.
Thanks
      11-01-2022, 01:53 PM   #2
freakystyly
Drives: F22 B58 6MT
One wheel vs two?
I still haven't found it necessary to have two.
The nannies on these cars are very good at not letting you do stupid things.
Getting moving from a stop would no doubt be easier with an LSD. Same as turning left a light for example...
      11-01-2022, 02:09 PM   #3
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
Thanks
I have an LSD on my Xdrive car and it has changed it and made it 1000x better. The rears in these cars are rather vague and unplanted around corners, in the rain and for sure in the snow. LSD is has been by far my favorite upgrade. An LSD will help you accelerate in the snow and provide more stability but won't help you stop. Tires are better for that.
F32 435i Xdrive
E70 X5 Diesel
Instagram - phils_bimmers
YouTube - phils_bimmers
      11-01-2022, 02:24 PM   #4
AllaVodka
Drives: BMW B58
Thanks
Thanks. My concern is the potential lock when a wheel loses grip, and doing a 180 or so with a rwd car
      11-01-2022, 02:28 PM   #5
Boostedphil698
Most LSDs don't lock fully. Now, plate LSDs can lock up to 40% which can be jarring in the snow. I'd probably recommend an helical LSD like Quaife or Wavetrac. They're progressive so they can vary "lock" depending on the situation. They're also very low maintenance, unlike like the plate style ones.
F32 435i Xdrive
E70 X5 Diesel
      11-01-2022, 03:13 PM   #6
White435
Citizen of ///M Town
White435's Avatar
Poland
84
Drives: 2014 435i xDrive
Did you get the M Performance LSD? I thought that you can't put LSD on xDrive cars.
      11-01-2022, 03:16 PM   #7
AllaVodka
Drives: BMW B58
Thanks. And for the quaife - how do I go about that one? My understanding is either I have to send them my differential and they put the lsd within my current casing?
      11-01-2022, 03:26 PM   #8
Boostedphil698
Depends on the car. All 335i and 435i Xdrive or RWD share the same rears so you could put an MPerf LSD in there... if you can still find one. I have a custom built Quaife LSD with REM polished gear sets.
F32 435i Xdrive
E70 X5 Diesel
      11-01-2022, 03:29 PM   #9
Boostedphil698
Seeing that you are located in the U.S. You can order one from diffsonline.com and also pay the core charge so you don't have to send your stock one in first. Once they rebuild the core they have with your desire LSD application, they'll send it to you and you just send back your old unit for a refund. I had diffsonline build mine and couldn't be happier. This job has to be done by the right person or it could get ugly if done wrong.
F32 435i Xdrive
E70 X5 Diesel
      11-01-2022, 05:03 PM   #10
AllaVodka
Drives: BMW B58
Thank you
