11-22-2022, 11:26 AM | #1 |
Rep 526
Any issues using non-BMW named approved oils?
Just realised the Title is misleading, so im asking if there's any issues with using the Named approved oils in ISTA that aren't BMW's own Twinpower brand (which i think is just rebranded shell?)
Had my car 4.5 years now. Always used BMW twinpower oil, 0w30 LL04. Always done it yearly, 1 year DIY, 1 year at a VAT registered garage to keep my extended-warranty valid. I always supply the oil+filter to the garage. But now 83212365929 is proving to be difficult to find - no bmw dealers near me have it in stock. ISTA has a list of "named LL-04 approved oils", and the 2 brands i can find easily in the UK are: Shell Helix Ultra ECT 0w-30 is £13.22 a litre. Castrol Edge 0w-30 £9.14/litre. The cheapest i've ever seen it (amazon black friday) The castrol is significantly cheaper. I don't track it or anything, infact most of the miles are either motorway or going to supermarket. Does anyone think going for Castrol Edge over my usual BMW Twinpower will make the slightest bit of difference to my car? Last edited by gippy; 11-22-2022 at 11:42 AM.. |
11-22-2022, 12:07 PM | #2 |
Rep 16,669
It's not rebranded Shell, not this week at any rate. It's now rebranded Castrol. The only thing that tells you is that when BMW's former marketing deal expired Castrol gave them the lowest price. Any LL04 will do. FWIW many BMW dealers have stopped stocking 5w-30 and have gone to 0w-20 to reduce inventory, as with LCI and later 0w-20 is the stock weight.
gippy234.00 |
11-23-2022, 09:35 AM | #3 |
Rep 10,545
Any LL04 is fine. Weight is irrelevant.
Castrol Shell Total Liqui-Moly Ravenol Pentosin Rowe
"Drive more, worry less. "
11-23-2022, 09:40 AM | #4 | |
Rep 1,505
Castrol is supplier for North America. Shell stayed supplier for rest of the world. But that is irrelevant. Point of approvals is for owners not to "fish" for oils. If it is approved, it is good to go. That being said, as of 2018 no 0WXX oil can be LL01 or LL04. So, if there are 0W30 oils with LL04, those are old batches. Depending on an engine, it is not a problem running oils without LL approval, but with corresponding MB approval like MB229.51. If it is N55 it is ok. If it is N20 generation approved oils are probably best way due to timing chain test these approvals have since 2018. |
11-27-2022, 10:11 AM | #6 |
Rep 63
Drives: 2016 340i xdrive M-Sport
Why not a 0w-20 BMW Longlife-17 FE+ instead of the 0w-30 on the 340i?
12-03-2022, 09:02 AM | #8 | |
Rep 10,545
Unless you live in extreme northern/southern latitudes there's no difference between 0w30 vs 5w30. UK weather is rather temperate. Not a lot of sub 0C days.
12-03-2022, 09:08 AM | #9 |
Rep 535
Pennzoil Platinum Euro 5w40 LL-01 (this is what I run in my 340i) or Pennzoil Platinum Euro L 5w30 LL-04 (requires more frequent oil changes).
12-03-2022, 12:51 PM | #10 | |
Rep 1,505
Now, if you are in North Michigan, this might be better solution during winter. |
12-04-2022, 08:01 AM | #11 |
Armchair Aristocrat
356
Rep 449
Am going with Pennzoil platinum euro 5w40 and if Blackstone shows high Fe wear in winter I'll switch to BMW TPT 0W30 in winter. How does that sound?
12-04-2022, 06:07 PM | #14 |
Rep 16,669
Sure, but just because you can doesn't mean that you should, especially in your neck of the woods. Why you're worried that 20 and 30 are too thin doesn't compute. If they were BMW dealerships wouldn't be using them. What you'd have a hard time finding at a dealership is 40, even for diesel.
12-04-2022, 07:45 PM | #15 |
Armchair Aristocrat
356
Rep 449
I don't think you understand winter viscosity numbers. The 5W in 5W-30, which the engine is approved for, is how free flowing the oil is in (W)inter. So 5W-40 and 5W-30 (or 5W-9000) have the exact same cold weather performance.
Add a tune to the engine to increase HP and that 40 viscosity might be perfect as well. And all this will be monitored for engine wear with Blackstone samples, so I'll stop right away if it's hurting the engine. |
12-05-2022, 08:18 AM | #16 |
Rep 535
Not exactly. The first number is for cold weather startup. Once the engine is up to temperature, the 2nd number is the running viscosity regardless of outside temperature.
12-05-2022, 12:11 PM | #18 | |
Rep 294
Drives: 2018 440i xDrive Gran Coupe
12-05-2022, 12:14 PM | #19 |
Rep 16,669
I've understood since I bought my first car. That was in 1969. If you lived in New Hampshire in the days of mineral oil and didn't understand the numbers you often ended up with a battery that died before the car would start when it got down below zero. It was when I worked in a dealership garage that I learned that 40 was for when you had an old engine with worn rings and bearings. Otherwise 30 was better.
12-05-2022, 10:45 PM | #20 | |
Rep 1,505
12-05-2022, 10:49 PM | #21 | |
Rep 1,505
Mclld performance is determined by Cold Cranking Simulator (CCS) that simulates performance of oil in temperatures from -35 to -5 using ASTM D5293 method. Since it simulates cranking, there is no free flow per se. |
12-05-2022, 10:58 PM | #22 | |
Rep 1,505
LL01 min 3.5mpas LL04 min 3.5mpas LL01FE min 3mpas LL17FE min 2.6mpas. HTHS can be different for two different 5W40 oils. For example, HTHS of Castrol Edge 5W40 is 3.6mpas, while HTHS of Pennzoil Platinum Euro 5W40 is 3.88mpas. HTHS is the most important value when it comes to protection. You have actually some 5W30 oils that have higher HTHS than 5W40 etc. It depends on base stocks, polymers etc. 40 grade, like all other grades are range, in this case 12.5 to 16.4cst. All LL approved 40 oils are "light" 40 oils, meaning they are on the verge to be 30. For example PPE 5W40 KV100 is 12.8cst. Now this is very important part, lower KV100 but higher HTHS indicates very sophisticated base stocks. This 5W40 will do better job protecting engine than any 10W40 oil for example without these approvals, even if it is synthetic. It is also better than Castrol 5W50 as it is more shear resistant and it could have HTHS even higher than ghat Castrol. So, grade per se is irrelevant from protection point. It is all about HTHS. All these oils have excellent cold performance. Their CCS is usually close to 0W. Aby 5W40 LL01 oil is suitable fir ANY of 48 states. I started my X5 35d with Valvoline European Vehicle 5W40 LL04 at -42 here in CO. No sweat at all. Is 0W30 or 40 better in really cold weather? Sure. And there are plenty options but not approved for BMW due to updates among BMW approvals in 2018. |
