12-14-2022, 06:00 PM | #2 |
![]() ![]() ![]() 2027
Rep 5,497
There was a thread a while back, and this was the recommendations:
BMW Harmon Kardon Sounds settings - from web forum Treble 0 Bass 0 L7 on 100Hz +5 200Hz -5 500Hz +1 1kHz 0 2kHz 0 5kHz -1 10kHz -1 For me (using a dB meter, I found this to better being flat): BMW Harmon Kardon Sounds settings - flat using soundmeter Treble 0 Bass 0 L7 off 100Hz -10 200Hz +3 500Hz -3 1kHz +5 2kHz -4 5kHz -4 10kHz +4 You will find that different volume levels with drastic change how it sounds though. |
12-14-2022, 11:45 PM | #3 | |
![]() 49
Rep 149
12-15-2022, 07:20 AM | #4 |
![]() ![]() ![]() ![]() 9070
Rep 17,325
https://www.wikihow.com/Use-a-Graphic-Equalizer
Use this to see what your system is doing: https://play.google.com/store/apps/d....audioanalyzer Set it on Spectrum Analyzer, Octave Bands, C-Weighting, Slow Weighting. Last edited by Billfitz; 12-15-2022 at 07:29 AM.. |
Wires2026.50 |
12-15-2022, 03:24 PM | #5 |
Rep 5,497
I don't like the surround either. I started with the first settings, and then ended up with the "flat" settings (second set). Seems to sound decent for low to moderate volume.
