12-15-2022, 12:32 PM | #1 |
![]() ![]() ![]() ![]() 270
Rep 668
Bolt ons: B58 gen1 Vs B58TU
As compared to a 2016 340 (320hp) will a newer model (2020 m340xi) have a higher hp if both are given state 1 tune and catted downpipe?
I was surprised to see car and driver had their stock m340 down the 1/4 at low 12’s and 115mph…. Seems a little faster than a gen1 b58 with tune and catted downpipe, no? |
12-15-2022, 09:30 PM | #3 |
![]() 840
Rep 1,463
No to TU making more power than Gen 1, all things being equal? Lol.
2022 CT4-V Blackwing 6-speed
eluded3256.00 |
12-16-2022, 02:20 AM | #4 |
2JZ-GTE
![]() 3256
Rep 4,250
TU make more
12-18-2022, 12:43 PM | #6 |
![]() 69
Rep 258
Stage 1 things should be pretty equal, the 11:1 compression ratio doesn't require you to neuter boost at all, maybe the TU can run a bit more timing, but higher compression also makes more power
12-18-2022, 04:37 PM | #7 |
![]() 840
Rep 1,463
Lol. TU motors make 40-50whp over Gen 1, stock for stock. That's a big ask for a stage 1 tune on Gen 1 to compensate for that and then whatever additional gains are had on the TU when those are tuned as well.
12-18-2022, 05:19 PM | #8 | |
![]() 69
Rep 258
The first b58TUs in the supra had 335hp and now they have 382 or whatever... Same motor besides manifold. |
12-20-2022, 10:18 PM | #9 | |
![]() 196
Rep 239
12-20-2022, 10:54 PM | #10 | |
![]() 69
Rep 258
But you're not going to be able to take advantage of the extra flow of the stock fuel system at stage 1 power levels... I don't think any of those improvements would net more than 10HP on a stage 1 tune, and we can't neglect that higher compression will make more power if you're not running into timing pull. |
12-21-2022, 08:20 AM | #12 | |
![]() 29708
Rep 200,629
Posts ![]() |
gen 1 Stage 1 91 octane: up to 18% HP / 26% TQ TU Stage 1 91 octane: up to 18% HP / 28% TQ
https://x-ph.com/sale/ Phone number 702-494-9435 ![]() |
12-21-2022, 11:12 AM | #13 | |
![]() 69
Rep 258
Obviously you're not going to get the same percentage gains from the 335hp one and the 382hp one. I bet that max% increase figure is using the 335hp TU as the baseline. If you had the same % increase on all TUs, you'd have a stage 1 2019 supra making 395HP and a 2021 stage 1 supra making 451, which just can't be correct. Last edited by morritse; 12-21-2022 at 11:24 AM.. |
12-21-2022, 02:02 PM | #14 | |
![]() ![]() ![]() ![]() ![]() 741
Rep 930
Drives: '17 F22,15 E84 M Sport,02 R53
2019 Supra 2 port head / manifold -2021 6 port manifold / head
Probably plays a part in this equation. Quote:
Integrated Engineering engine mounts, Dinan CAI, AA catted DP, Remus resonated cat back.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, VAC monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
12-21-2022, 02:18 PM | #15 |
![]() 69
Rep 258
12-21-2022, 07:39 PM | #16 |
![]() 43
Rep 153
I have a 2016 340i Msport
1st gen b58. Stage 2 + 93 I’m pushing around 470hp Catless dp Tu HPFP Intake. Muffler delete. It’s fast enough lol I’ve ran e30 and e50 And it’s a monster It’s scary lol. |
12-21-2022, 08:17 PM | #18 |
![]() 69
Rep 258
12-22-2022, 04:11 PM | #19 | |
![]() ![]() 32
Rep 85
Drives: 2016 340ix MPPSK| 2015 R60 JCW
Could changes in other parts of the drivetrain make a differnce vs the M340i? I recall I read that the M340i comes standard with the M-Sport Differential which is electro-mechanical and works with xDrive. The F30 on the otherhand had a ??mechanical?? M-Sport Differential which was an option only available on RWD cars |
12-22-2022, 05:22 PM | #20 | |
Novice
349
Rep 724
TU engine makes more due to a slightly larger turbo and fueling upgrades. I do not think their mechanical revisions (such as the timing chain) would make any more power from factory. |
12-24-2022, 01:08 PM | #21 |
Cheapskate
4612
Rep 5,015
Stage 1
TU > Gen 1 Stage 2 TU > Gen 1 Stage 2+ Gen 1 = Stage 2 TU Thanks for coming to my Ted Talk |
12-24-2022, 04:39 PM | #22 |
![]() 840
Rep 1,463
"bUt tU sTAge 1 WOn't hAvE aNY DIffErENceS iN PoWEr oVEr gEN 1 StAGe 1"
