02-23-2023, 08:22 PM | #1 |
Rep 36
How have acceleration times gotten so good just in the past 10 years?
And I know it's not tires tire tech couldn't have evolved this much in 10 years.
Just 10 years ago for example 4.5-4.8 seconds was a 335i time but even a non AWD one today does it in 4.0 sometimes less. Same with the non xdrive m3 doing 3.7 or less with 500hp, but a 600hp tuned f80, barely reached 3.7? And similar examples. Is it better suspension? Better power delivery to the axles? Less drive train loss? IT seems cars with 350hp nowadays can hit 3.5 seconds or less whereas 10 years ago they averaged 5 seconds or more and AWD only shaved off 0.3 seconds max from the 5 seconds. What happened? I'm also factoring in torque here too let's say similar torque to hp |
02-23-2023, 09:27 PM | #4 |
Rep 125
Tires, tons of electronics, automatic transmissions, and all wheel drive.
Current rides: 2011 BMW 328i Coupe 6MT, 2009 Honda CBR600RR
Works in progress: three 1974 Honda CB750s Previous rides: 2009 VW GTI 4D 6MT, 2020 Yamaha R3 |
02-23-2023, 09:35 PM | #5 |
2024 M440i GC (G26)
285
Rep 511
ATs today are worlds better than anything from past generations. Add in traction control systems and (basically) no-lag forced induction, and there's your answer.
02-24-2023, 03:14 AM | #6 |
///M driver
20299
Rep 671
Compare one of the ultimate performance machines of the early 1960s -- the Ferrari 250GTO -- with anything today and you are amazed at the progress over the years.
EDIT: Looked up the published 250GTO acceleration time to 100 km/hr (0 to 62 mph) in the respected work on Ferrari by Rainer W. Schlegelmilch and the number given is 5.6 seconds.
'22 G80 M3 6-sp Portimão Blue/Tartufo (For sale)
'25 M850ix GC (Ordered) Last edited by Llarry; 02-28-2023 at 05:13 AM.. |
02-24-2023, 07:24 AM | #7 |
Rep 427
The tuning of the turbo and 8 speed automatic seems to be the key for BMW. Their underrating of total horsepower also helps.
Most BMW engines seem to get max torque as low as 1500 rpm because they tune the turbo boost for low end torque. This feels like really good power in normal driving, so you can keep your foot out of it and get decent gas mileage. However, if you do hit the accelerator hard they use the combination of the 8 speed auto and turbo boost to keep power/torque high almost constantly during acceleration. That provides great 0-60 times. For the M340i you end up with 0-60 of about 4 seconds, and highway gas mileage of 32-35 mpg. The best of both worlds. |
Efthreeoh18674.50 |
02-24-2023, 10:44 AM | #9 | |
Rep 787
It takes a management system to not overwhelm the traction available. Cars got to a point where more power didn't get put to the pavement and turned into motion, it just overwhelmed traction. Not unlike antilock brakes, (but inverse), managing traction by electronic intervention of the brake systems pressure, limiting torque applied to the rotor to maintain that traction. Modern ABS systems reduce stopping distance in almost all scenarios. |
02-24-2023, 11:14 AM | #10 |
enthusiasm > practicality
4031
Rep 2,245
Drives: 987 CS | G35x
TC and especially launch control in turbo equipped vehicles. Having full boost when dropping the hammer is a godsend when playing stop light heroics. 5-60 is a much better indicator of real world acceleration. My go-to measurement from idle, though, is trap speed through the 1/4.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
02-24-2023, 11:27 AM | #11 |
Rep 4,078
All wheel drive, tire technology, engine efficiency, launch control.
Weight is one of the biggest contributors that doesn't get spoken of enough. Cars are disgusting pigs now. |
02-24-2023, 02:10 PM | #12 |
Rep 3,307
I don't even pay attention to acceleration numbers of new cars anymore. What is the point really, they are all plenty quick enough. I couldn't even tell you the 0-60 of G87 M2, even though I am somewhat interested in it.
02-24-2023, 03:18 PM | #13 |
Rep 3,803
They are going after 0-60. Supercars have first gears that go to 60, most sporty cars have second gear going to 60-62 by design for that better number. Measurements have been changed to factor in rollout and temperature in mag testing.
If I want to know a cars acceleration I'll look at 5-60 or 1/4 trap speed. To me that's more 'real world' since I'm usually flooring it when the car is already in motion. FYI a tesla model 3 performance still beats out a g80 comp xdrive on 5-60mph. Great video if you have the time :
2018 Porsche GT3 6MT Previous: Ferrari 458 | R35 GTR | F80 M3 | F87 M2c | E46 M3 | E36 M3 | Scion FRS |
02-24-2023, 03:49 PM | #14 |
Rep 7,473
Maybe learn to read the OPs question. The difference between 0-60 on fast cars, EVs, and particularly F8x to G8x is the closed loop traction control. They don't need closer gearing to be faster and haven't for over a decade. All fast cars have been TRACTION LIMITED for a long time. I realize that may be hard to understand if you haven't driven anything faster than an N52 E90.
02-24-2023, 04:54 PM | #15 | |
Rep 7,473
Maybe you should drive a C6 vs C7 or F80 vs G80 and figure it out yourself. The newer versions of both just go without allowing nearly as much wheelspin. Almost like a Tesla which will give you as fast a launch as the surface will support anytime you mash the throttle. Neither are as effective as Tesla's controller still, but it's not because of torque or gearing. The bottom line is he asked why a F80 and G80 RWD accelerate differently 0-60 as an example and the reason for that is the improved traction control from Bosch. Last edited by chris719; 02-24-2023 at 05:02 PM.. |
02-24-2023, 05:01 PM | #16 | |
Rep 2,446
Drives: 9Y0 Cayenne S
Specific output has trended higher with direct injection, widespread turbocharging and combustion efficiency (converting chemical to kinetic energy). The other factors you listed are far less important than power and torque. |
02-24-2023, 05:06 PM | #17 | |
Rep 7,473
Check out 0-60 vs 5-60 for EVs, for example. EVs are fast from a stop because they don't spin. If you are fast enough, you can allow only "microslip" and maximize the traction offered. Last edited by chris719; 02-24-2023 at 05:12 PM.. |
02-24-2023, 05:10 PM | #18 | |
Rep 7,473
02-24-2023, 05:17 PM | #19 |
Rep 14,187
Drives: G82 M4C X-Drive
Dumb question: I don't use launch control much, but when I do, I have to turn off DSC. Does that mean that DSC is not active during Launch Control? I always thought it was doing something even though it is "off" during Launch Control. Case in point: If you put too much steering input during Launch Control, it will cut power (annoyingly), so the DSC is definitely doing something.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
02-24-2023, 05:21 PM | #20 |
Rep 11,121
Drives: M4 CS. Former G82, x2 F82, F80
I think EVs have forced ICE makers to up their game to not get completely demolished in the meaningless stoplight wars.
02-24-2023, 07:10 PM | #21 | |
Rep 7,473
btw, I work with and design control systems regularly including Nyquist and Bode stability analysis. I'm pretty sure I know what I'm talking about. Your initial post was wrong and is wrong. The gearboxes have almost nothing to do with the improvements in 0-60 times. I didn't even reply to you directly, FWIW. Last edited by chris719; 02-24-2023 at 07:29 PM.. |
02-24-2023, 08:13 PM | #22 | |
Rep 36
And the M cars for sure vs just m sport. Never cared for 0-60 but I think my question has been answered. I'm now more interested in 5-60 as others have pointed out and the differences are definitely surprising and not surprising at the same time |
