BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > LCI wiring harness convert to halogen pins
      03-03-2023, 04:18 PM   #1
TylersF30
TylersF30's Avatar
Drives: F30 2016 328i
Hello!
I am trying to install an aftermarket headlight assembly onto my 2016 f30. Everything is bolted in and looks good. However, the stock wiring harness is set up for LCI (2016+) LED headlights (See reference image). The Aftermarket assembly is originally made for the halogen models with a different pin setup than mine (See reference image).
The sticky post "US F30 OEM Adaptive Xenon Retrofit DIY" covers how to swap the pins in the google doc. However, my harness has different colored wires, and I'm unsure which wires to put in which pin to basically revert to a halogen harness which the aftermarket headlights are made for. I am thinking if I can swap the right pins, hopefully, that will make the headlights work. I am unsure if there will be any coding I'll need to do after but I'll handle that once I get there.
UPDATE: I switched over the pins with trail and error but the headlights still don't work properly. Unsure of where to go from here
