| 04-21-2023, 12:16 PM | #1 |
Rep 6,143
The 2 series courtesy car is gone and bmw who are looking after me well have swapped me into this.
I'm not sure how one goes about plugging in as in is there a point in doing it if you don't have home charger? and where can I charge it? |
| 04-21-2023, 01:07 PM | #3 |
Rep 1,756
A friend has been running about in one of these for a couple of weeks.
She has a troublesome Peugeot 5008....Company car. Hence the 330e rental. She didn't like it....Good to drive (bear in mind she's only had her 5008 on the road for a couple of days this year!! So has been in many hire cars). Didn't plug it in as she has nowhere to plug it in to. Small boot due to batteries, so no dog cages fit! And small petrol tank so she feels as if she's filling up every couple of days. |
KRS_SN17081.00 |
| 04-21-2023, 01:53 PM | #4 |
Barge driver
8948
Rep 12,707
I think you can charge it at home using a 3 pin to type 2 connector should be full after a night of charging I would have thought, might as well so you get the full power and experience a bit of EV running
350d cab/Z4C
| 04-21-2023, 02:00 PM | #5 |
![]() 1051
Rep 1,534
Is there a charging cable in the boot? You’re a member of David Lloyd are you not? I think they’ve got charging points on site.
Gone: Tesla Model Y LR, G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
KRS_SN17081.00 |
| 04-21-2023, 02:07 PM | #6 |
Rep 6,143
KCH1984 Wills2
There are these 2 in the boot. I'm guessing the yellow one is the 3pin and it goes into an extension cable at home. I'm thinking the other one may work at david lloyds. Leap of faith hope I dont screw up home electrics etc. Will give it a go just to get a feel |
| 04-21-2023, 02:15 PM | #7 |
Rep 3,343
The 3-pin plug one is a 2.3kW charger (aka 'granny cable') - the battery would take 4-5 hours to go from empty to fully charged using that.
The other cable is 7kW max, but I'm not sure if the car supports that charging speed, or if it maxes out at 3.6kW charge capacity - it's not that important for a hybrid, as the battery is quite small, so not like you've got a huge battery to fill up. |
| 04-21-2023, 03:52 PM | #8 |
![]() 173
Rep 209
Yeah just plug the yellow cabled 3-pin in.
It will pull </=10a so as long as your wiring is ‘normal’ ie installed to regs, then any 3-pin socket will be rated at 13a, so just plug and go. The car will tell you straight away that it’s charging. Small batteries in these (albeit they take up loadsa boot space so it won’t take long to charge as robbiep says |
KRS_SN17081.00 |
| 04-21-2023, 06:29 PM | #11 |
Rep 6,143
| 04-22-2023, 08:52 AM | #12 |
![]() 1051
Rep 1,534
Is your F15 sitting low at the back, or just the angle of that picture?
| 04-22-2023, 09:05 AM | #13 | |
Rep 6,143
Not great for cars with air suspension as ive had the airbag on that side replaced once. Once started and moving it levels out. |
| 04-24-2023, 01:53 PM | #15 |
Rep 6,143
Charging has been a hit and a miss..couple of times the extension cable connected to the 3pin seems to have tripped terminating Charging with the message 'Charging error voltage too low'.
The car is very comfy soaks up broken roads etc very well no transmitted noise into the cabin..g series is a million miles from the f 3 series I still think if it had around 80 miles range and 2hrs to charge and the engine underneath I'd buy it tomorrow. |
| 04-24-2023, 02:02 PM | #16 | |
![]() ![]() ![]() 10014
Rep 13,291
https://www.autocar.co.uk/car-review...23-first-drive Last edited by isleaiw1; 04-24-2023 at 02:09 PM.. |
| 04-24-2023, 02:36 PM | #17 | |
Rep 6,143
| 04-24-2023, 02:57 PM | #18 | |
Rep 13,291
I added 140miles in 60 mins at a public charger today with a battery that was pretty cold... |
| 04-24-2023, 04:19 PM | #19 |
Rep 3,343
Regarding home chargers :
With the 'granny cable', it'll put in <10 miles of electric-only range per hour of charging A 7kW 'fast' charging point (the max you can get at home, unless you want to invest in a 3 phase supply) will put in 25-30 miles of range per hour. The faster public ('rapid') chargers are anything from 22kW upwards (80 miles range per hour or higher) The 330 has a max charging rate of 3.7kW/hr - so even if you had a fast charger at home it wouldn't be able to make full use of it - but it'd be pointless investing in that sort of charger for a 330e or other hybrid, as the battery is quite small. |
| 04-25-2023, 04:02 AM | #20 |
![]() 1111
Rep 1,742
KCH19841051.00 MashinBenzin8641.00 |
| 04-25-2023, 05:41 AM | #21 |
Rep 6,143
My first all electric trip to work. I'm loving the silence and lack of drama to get going. The suspension is great. Even on the worst broken roads there is no chatter. Its on 18in rft's
When I started from home it showed 18miles electric range available Having done 13.6 miles it still says 13 miles available. I think I'll get home in electric mode only. I did drive very sensibly. |
| 04-25-2023, 09:02 AM | #22 | |
Barge driver
8948
Rep 12,707
350d cab/Z4C
| Bookmarks |
