07-01-2023, 10:29 PM | #1 |
Rep 13
Lane departure issue
THIS HAS BEEN RESOLVED/FIXED SEE COMMENTS FOR HELP
Hello f30 fam, Long time lurker, first time poster. This forum is honestly fantastic so I'm hoping someone can help me navigate through this issue i'm having. Car: 2016 328d xdrive wagon (f31) While driving, if I get the Lane departure to activate (by driving over a lane without blinkers on as an example) i will get an error on the dash saying the lane assist is malfucntioning. The ISTA errors are: 48004 KAFAS interface (TLC ready for operation):signal invalid 48004A SZL interface *steering wheel vibration): Signal invalid 800A07 Vibration motor in steering wheel faulty I am thinking it may be a faulty Steering Wheel Vibration Generator, but I am not sure why I would get a KAFAS and SZL code as well. I also should note that I also have 800BE0 and 800BDB code because my side camera is currently being replaced (i ordered it, it stopped working) but i do not think these issues are related. Also, my active blind spot monitor that will also malfunction, not sure if it happens during lane switches with lane departure, or independently. Not sure if this is related to either the camera missing, or the lane departure issue. Your help is greatly appreciated! Last edited by dazzles; 07-14-2023 at 05:00 PM.. Reason: F32=/=F31 |
07-02-2023, 09:37 AM | #2 |
Rep 13
Edit 1:
I ordered the vibration generator, going to keep this thread updated to help people in the future if they encounter this behavior. Last edited by dazzles; 07-02-2023 at 09:38 AM.. Reason: Typo |
07-02-2023, 02:56 PM | #3 |
Rep 1,595
Sensible decision. But I would also check to exclude any power/ground/wiring issues going to the vibration motor itself.
07-02-2023, 05:13 PM | #4 |
Rep 1,117
I find it interesting people retrofitting this as I had it and ended up turning it off, as many others have mentioned they do the same. Maybe if driving drunk or distracted or long hours of highway driving with no sleep. Otherwise, I’m not sure of the attraction.
Wires1664.50 |
07-02-2023, 06:49 PM | #5 | |
Rep 1,595
07-02-2023, 07:29 PM | #6 |
Rep 1,117
Cannot be much help. On my F30 I did not have heated seats or heated steering wheel but know the leather msport steering wheel was a heated steering wheel. It is listed on realoem as needed for lane change and drivers assistance. I also know to be careful of used steering wheels as many come from cars where the airbag was deployed and replaced by insurance. BMW calls for replacing the steering wheel after airbag deployment.
https://f30.bimmerpost.com/forums/sh....php?t=2029950 |
fe7565556.50 |
07-02-2023, 07:40 PM | #7 | |
Rep 4,912
Sorry no help to your original question OP, other than mine is disabled because I don't like it. |
07-02-2023, 08:49 PM | #8 |
Rep 13
OCD
I am fixing this for two reasons:
I am very OCD with my vehicles, and i like everything to work, whether or not I use it. To make matters worse, i've always loved BMW's and that's basically the perfect and worst OCD vehicle, anytime there is any potential issue, you get lights and errors everywhere. The other, more sensible reason I want this fixed, is because my blind spot sensor will also not work (i presume because there is a vibration in the steering wheel when there is danger??) I erased all codes, turned off lane assist, and turned on blind spot monitoring, went for a drive, and as soon as i tried turning into a vehicle with my blinkers on, I got the error that blind spot is malfunctioning. The two errors codes I have now are: 48004A - SZL interface (steering wheel vibration) Signal Invalid 800A07 - Vibration motor in steering wheel faulty I believe this strengthens my hypothesis that it's indeed this fella. |
07-02-2023, 08:51 PM | #9 |
Rep 13
Should have done that before ordering the part, but, I suppose I'm going to be able to test this once the part gets here. Is there a simple way to test this? I don't believe there's always power going to the motor in the steering wheel? It likely only sends power when the ECU triggers the motor on?
07-02-2023, 09:23 PM | #10 | |
Rep 1,595
07-08-2023, 02:51 PM | #11 |
Rep 13
Final edit and fix
Posting a final edit for anyone who may have this issue in the future.
The issue was the Steering Vibration Generator part no: 32337849416 Be careful, because depending on what steering wheel you have, there are two types of steering vibration generators that will fit your car. 32337849416 - for MSPORT steering wheel aka the skinny boy 32336787451 - for SPORT steering wheels aka the thick boy Good luck to everyone and thanks for your attempt to help. Adieu |
07-08-2023, 04:13 PM | #12 | |
Rep 1,595
07-10-2023, 06:23 PM | #13 | |
Rep 13
07-10-2023, 09:50 PM | #14 |
Rep 1,595
Thank you. Will see... I think I have all the parts.
07-11-2023, 08:01 AM | #15 |
Rep 4,912
08-01-2023, 01:22 PM | #17 | |
Rep 8
03-22-2024, 11:32 AM | #18 |
Rep 13
Sorry, haven't been on in a while. I think it made perfect sense, the module would have likely caused the options to always be off (think my options worked unless i have triggered them in a way to get the vibration mechanism to engage, in which case it would turn off and display errors/ista codes
