09-14-2023, 10:50 AM | #1 |
Rep 1,182
Drives: 2015 BMW 435i Xdrive MSport
Pure 750 Dyno Results
Hey guys,
In House Peformance recently dynoed his 535i built motor running the Pure 750 and the results were impressive for how hot it was. Check out the video
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
09-14-2023, 01:44 PM | #2 |
Rep 1,117
There’s 12 minutes of my life I’ll never get back
TLDR: |
InHousePerformance115.00 JPuehl104.50 |
09-14-2023, 04:08 PM | #3 |
@_sunbish
301
Rep 633
Are we counting the spikes as real hp
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
InHousePerformance115.00 houtan719.50 |
09-15-2023, 09:05 AM | #4 |
Rep 194,559
Thank you for sharing
Boostedphil698467.50 |
09-15-2023, 09:58 AM | #5 |
Rep 4,975
You mean to tell me that thing doesn't reach spool until 5000RPM and only makes 600whp?
What a waste. |
09-15-2023, 10:22 AM | #6 |
Rep 1,182
Could be the tune.
09-15-2023, 04:24 PM | #7 |
1318
Rep 3,593
LOL at smoothing set to zero.. thats absolutely not how to run a dyno lol
2017 m240i xDrive 10.67@132.32mph w/bm3
09-15-2023, 11:07 PM | #8 |
Rep 161
Drives: 2015 535i
Well since Im an active member here maybe I should say a few things to handful of people that dont want to tag me. Want logs here ya go this is the log from pull in question…
IHP Pure750 Dyno Log IAT mid to high 90s, DA 4400 ft, and only 28.7psi last street logs shows 31/32psi so without heat soak should see better numbers. But I can prove it next week. smoothing numbers ? Well here you go smoothing set to 3… Anyone else have any questions?
2015 F10 535i
FBO BM3 Pure Stage 2 Dorch Stage 2 HPFP E50 tune by Cary Jordan EOS EkP Module Walbro 525 LPFP Variant Argon 20? Wheels E60 M550i Sold “Im a crazy car guy” If it has a motor, it has my attention |
09-15-2023, 11:10 PM | #9 | |
Rep 161
Drives: 2015 535i
Pure 750 street Log Hope I didnt waste your time…
2015 F10 535i
harkes1112.00 |
09-16-2023, 03:47 AM | #10 |
Rep 2,410
Don't compare spooling to 20psi with spool to 30psi. Compare them spooling to eg 15psi. Also, higher gears will spool earlier in the rpm band and remember to compare WOT start RPM.
(A Dane in China) |
InHousePerformance115.00 |
09-16-2023, 06:59 AM | #11 | |
@_sunbish
301
Rep 633
Keep in mind, most dynos can’t load the car like the street can. I agree with the switch to the full frame for your goals of 700whp. I don’t think there’s any other option on the market to hit that. All in all I applaud your build, it gives people who’ve wanting to see this turbo produce numbers a great idea of what to expect.
09-16-2023, 08:04 AM | #12 | |
Rep 4,975
09-16-2023, 08:08 AM | #13 | |
1318
Rep 3,593
09-16-2023, 08:12 AM | #14 | |
Rep 161
Drives: 2015 535i
Im getting snippy cause instead of people wanting to ask questions and appreciate someone in the communitity trying to provide real world data for this turbo everyone wants to be nagtive and talk trash.
2015 F10 535i
09-16-2023, 08:15 AM | #15 | |
Rep 4,975
Direct your frustrations at people who deserve it (or better yet, just ignore it!) and enjoy your car. FYI this is the second dyno I’ve seen of the PS3 with late spool - houtan had the prototype. Since no logs were posted when I made my comment, all I see is 1500rpm for 600whp. |
09-16-2023, 08:23 AM | #16 |
Rep 161
Drives: 2015 535i
Theres not going to be a huge difference between 3 and 5. Again this wasnt to get final numbers this was to make sure I resolved my issues on the dyno that I experienced in California. We have, so when I go back I will be sure to display smoothing of 5 for everyone to see.
2015 F10 535i
09-16-2023, 08:30 AM | #17 | |
Rep 161
Drives: 2015 535i
Two, Houtan is PWG and his turbo ended up not being the production intent turbo. So cant really use his data. The only clean data Pure got was from a guy in Europe and thats where their advertised 610whp on E30 at 25 psi came from just fyi.
2015 F10 535i
09-16-2023, 08:42 AM | #18 | |
1318
Rep 3,593
Don't be mad at me for calling you out on what can be considered shady.. I lost all respect for you as soon as i seen that, you should know better... smoothing is always at 5.. always, it doesn't matter what the difference is between 5 and 3.. you use 5. I would expect a little more integrity from someone like you in here. You posted it on youtube man, do better.
09-16-2023, 08:42 AM | #19 | |
Rep 161
Drives: 2015 535i
Im not sure if the Pure 800 is the same I believe the 750 is a 62/58 but I could be wrong I have to look again. But the spool is very similar to the PS2 and in 5th gear reaches full boost by 3900rpm. My 0-60 times are a little faster then my PS2 as well and that was in the biggining so I should try to re run that with the newest revisions. Az is suppose to finally start cooling down so that will help the data cause right now DA is still 4200-4500 ft with our ambient air still 100 degrees by 10 am smh.
2015 F10 535i
houtan719.50 |
09-16-2023, 08:47 AM | #20 | |
1318
Rep 3,593
Are you on Instagram? I'll get you guys connected as he's running into an issue with tq limiters and you may be able to help him out...
09-16-2023, 08:51 AM | #21 | |
Rep 161
Drives: 2015 535i
If I was being shady I would of made sure to leave the smoothing value not visible or out of the frame but its right there for everyone to see so Im not being shady at all. I made a video showing the progress and You want to say you lost all respect for me and thats fine I could care less cause I wasnt trying to be milicious at all.
2015 F10 535i
09-16-2023, 09:38 AM | #22 |
Rep 2,463
Nice result and thanks for sharing! Is there a mod list for your car?
Jealous you can run that much boost. I’m stuck at 25psi until MHD has time to help me out. The e series n55 DCT cars are stuck unfortunately. Anytime I go past 600whp I get cylinder 4, 5, or 6 misfire even though my logs are beautiful. The Dyno and logs are just tools to show the car’s performance. Dragy times would be another one. My turbo does spool slower than when I had the ps2, if I am bogging the motor down, such as a Dyno pull or grabbing a log in 4th from 2,500. But if I am at at 4k, I’m spooled up just as fast as my PS2. My car is much much faster than my PS2, and my dragy times make that obvious. Thanks again for posting, hoping I get to run that much boost someday!
n55david1317.50 |
