11-18-2023, 12:23 PM | #1 |
Rep 19
EPS, SZL and SAS question.
Installed used EPS, used SZL with its original SAS
This is what I believe to be needed: EPS vin/vo coded and calibrated SZL vin/vo coded SAS calibration, issue is one direction reads -19xx and the other direction reads -9xx. Center was triple verified. All are used parts However after install, EPS worked, SZL steering wheel buttons and such function. But, still have Chassis stabilization: drive moderately, Steering: Drive moderately, Cruise Control malfunction. All presumed to be due to program/coding and calibration/ reset. Am I some what correct as to presuming these issues to be the case? Any insight would be greatly appreciated! |
11-18-2023, 01:45 PM | #3 |
Rep 19
Ret SFC
From protool 483c2 eps control unit steering angle fault directional stability 48002c Icm acc interface dsc D01c0c no message actual power rack current position D01b26 no message current position D01b2a signal invalid transmitter eps D019bf no message actual steering torque driver actuator D02d07 signal actual steering torque driver actuator invalid 480ab8 dsc control unit vehicle start with moving vehicle or driving condition unknown 4823c2 eps control unit steering angle initialization fault, directional stability not learned Yeah I think that’s all. LOL Last edited by NDA601551; 11-18-2023 at 01:46 PM.. Reason: Info |
11-18-2023, 02:28 PM | #5 |
Rep 19
No Sir, haven’t done so. I am a diehard E46’er since 2002. My first venture of into the f series. Have ESys, in process of downloading ista D. To plunk around a possibly figure it out myself. Another option would be for someone remotely perform these operations. Really looking for others takeaway of what I’ve stated, to see if my logic is on the right path.
11-19-2023, 07:57 AM | #8 |
Rep 19
I’ve been attempting to dl ista without any luck on the mega sites. I have a dedicated laptop and the enet cable. How does that work, remotely that is?
12-09-2023, 09:58 AM | #10 |
Rep 21
Hi I wonder if anyone could shed any light on my problem or sort it out. Car was in a small bump someone caught the front driver corner but in doing so clipped the tire and turn steering wheel and wheels no one was in the car when this happened no power on either no visible damage to the steering but orange steering warning light on. And no eps cleared fault codes expecting it to start working but nothing fault code is 4823A1 EPS control unit internal fault
02-19-2024, 10:57 AM | #12 | |
Rep 61
BMW f31 320d Modern 6MT
04-16-2024, 08:19 AM | #13 |
Rep 59
Hey I know this has been awhile, but I really need some help. I should have ISTA P/ISTA +D up and running later today. I have the same situation as the other guy you offered to help. Replaced my EPS unit, and need to program/initialize it. Thank you!
