12-11-2023, 08:05 AM | #1 |
Rep 6
Strange Issue with Battery Drain
Had the battery drain while stopped error, battery died overnight while sitting. Had battery replaced. Same issue a day later, dead battery. Charged battery up and car runs fine, but I'm concerned about the battery drain issue. Used Bimmerlink to export errors and listed below. Any ideas of where to start?
1 Error Memory Date: 12/11/23 7:37:49 AM VIN: WBA4B1C5XFD418234 Crash Safety Module 1 error C9542D: Vehicle speed - signal invalid allround-view camera 1 error 800B9F: Undervoltage detected Automatic luggage compartment lid actuation 1 error 801703: HVAC: undervoltage detected Central Gateway Module 3 errors CD0487: Synchronization process failed, CC was not yet synchronized when the error memory lock was released 801C15: Failed to fall asleep at 30B 801C20: Central fault memory full Digital Motor Electronics 6 errors 1C4110: Oil condition sensor: malfunction 201004: CBS client: output of substitute value 213601: Power management: Quiescent current violation 213501: Power management: Battery deep discharge 2 CDC104: A-CAN, message (data gear train, 0x1AF): missing CD9435: A-CAN, message (data gear train, 0x1AF) in the event of undervoltage: missing Integrated Chassis Management 8 errors 480131: SBS function - diverse computing VX 480134: SBS function - direction of travel unsafe with vx greater than 2 m / s 480006: Local power supply undervoltage 4827A5: SBS function - vertical acceleration - diverse computing HL software D014A1: Signal error (actual position EPS, ID: AVL_PO_EPS) qualifier D017A3: Signal error (actual number of encoder edges wheel, ID: AVL_QUAN_EES_WHL) - Invalid D017C5: Signal error (actual wheel speed, ID: AVL_RPM_WHL) - Invalid D017C6: Signal error (actual wheel speed, ID: AVL_RPM_WHL) - Undefined Dynamic stability control 6 errors 4809AB: Global power supply - external undervoltage 480AB8: Internal condition management Complete scope of monitoring D35A53: Signal error (actual steering angle front axle, ID: AVL_STEA_FTAX) qualifier 480A12: Brake pad sensor - rear axle - wear limit reached 4806B8: RDCi wheel electronics front left no reception 48069E: RDCi calibration wheel detection not possible Electromechanical power steering 2 errors 4823FD: Power supply - Local undervoltage, shutdown of steering assistance 482394: Sensor - rotor position - steering angle - loss of multiturn value 3 Touchbox 1 error 806182: Undervoltage detected Roof function center 3 errors 801A4B: SINE: External supply undervoltage 030205: SHD, Hall element A: Hall element defective or line interruption 801A38: Undervoltage detected Gear selector switch 1 error 802696: Undervoltage detected Instrument panel 7 errors E11460: Message (data display gear train, 0x3FD) missing, receiver KOMBI, sender EGS DKG E12C1C: Interface DME DDE (data drive train 2, 0x3F9): signal invalid E11420: COMBI: ServiceCall cannot be executed B7F685: COMBI: Undervoltage detected B7F668: COMBI: system time was reset E11514: Message (longitudinal acceleration center of gravity, 0x199) missing, receiver KOMBI, transmitter DSC / ICM_QL E11515: Message (lateral acceleration center of gravity, 0x19A) is missing, receiver KOMBI, transmitter DSC / ICM_QL Telematic Communication Box 2 errors B7F325: Emergency loudspeaker: interruption 4 B7F327: Microphone 1: Short circuit to ground Headunit High 1 error B7F86B: External undervoltage Controller (iDrive) 2 errors E2EC08: Signal (0x330) received invalid: Distance_km 801405: Undervoltage detected Seat module, driver 1 error 802A1E: No seat adjustment due to engine start condition Rear electronic module 10 errors 030101: FH FAH, relay closing, no output voltage: relay adhesive or fuse defective or short circuit to ground 030118: FH FAH: No engine start due to overvoltage / undervoltage 030120: FH FAH: The system is not standardized 030181: FH BFH, relay closing, no output voltage: relay adhesive or fuse defective or short circuit to ground 030195: FH BFH: invalid characteristic, no standardization available 030198: FH BFH: No engine start due to overvoltage / undervoltage 0301A0: FH BFH: The system is not standardized 8031D9: On-board voltage too low 804811: Supply undervoltage 8V5 8048C1: Rear window heating, relay: line to relay interrupted or short circuit to positive 5 Integrated automatic heating / air conditioning system 5 errors 8011C1: External FBM and audio control panel: key clip detected 801237: Rear window heating: Reduction of heating output due to power management E71408: Message (DT_PT_2, 0x3F9, FA): TEMP_ENG_DRV invalid signal E71430: Message (STAT_FOG_UP_FRONT, 0x2D1, FA): Timeout E7143A: Message (STAT_FAS, 0x232, FA): Timeout |
12-11-2023, 08:51 AM | #2 |
Rep 16,671
There's too much there to make sense of it. Clear them all, see if any come back. The two most common parasitic power drains are the dashboard and the water pump. Both have been extensively covered here.
12-11-2023, 08:18 PM | #3 |
Rep 6
I cleared them and the main ones I notice come back were...
801237: Rear window heating: Reduction of heating output due to power management and 030120: FH FAH: The system is not standardized I'll export and upload the full list after clearing tomorrow |
12-12-2023, 06:20 PM | #4 |
Rep 6
Cleared memory, let it charge overnight, sat all day today. Crunk it up and these are the errors now.
Date: 12/12/23 7:05:08 PM VIN: WBA4B1C5XFD418234 Crash Safety Module 1 error 930AA3: Supply voltage: Undervoltage detected in self-test (PDC) Central Gateway Module 1 error 801C20: Central fault memory full Digital Motor Electronics 6 errors 213501: Power management: Battery deep discharge 213601: Power management: Quiescent current violation 213A21: On-board power supply voltage, working range: voltage too low 1C4110: Oil condition sensor: malfunction 201004: CBS client: output of substitute value 213901: Power management: active consumer reduction Dynamic stability control 3 errors 480964: Local power supply - severe undervoltage 4809AB: Global power supply - external undervoltage 480A12: Brake pad sensor - rear axle - wear limit reached Electromechanical power steering 2 1 error 4823D4: Power supply - global undervoltage Touchbox 1 error 806182: Undervoltage detected Front electronic module 7 errors 030020: FH FA: The system is not standardized 804011: Supply undervoltage 8V5 804033: ZSG game protection: wake-up inputs blocked 8040B9: Deactivation of terminal 30B: OSFG reached 8040BB: Kl30B active: start capability limit reached or Kl. 30B active for a long time 8040BD: Terminal 30F reset or shutdown 804256: Outside mirror right (LIN): heating or electric chrome: defective Roof function center 1 error 801A38: Undervoltage detected Instrument panel 2 errors E11482: Message (Alive counter security, 0x0D7) not up to date, receiver KOMBI, sender ACSM E12C1D: Information: Terminal 30f was switched off (terminal 30 delay time controlled by errors, 0x3AC) Telematic Communication Box 2 errors 3 B7F325: Emergency loudspeaker: interruption B7F327: Microphone 1: Short circuit to ground Headunit High 1 error B7F86B: External undervoltage Controller (iDrive) 1 error 801405: Undervoltage detected Rear electronic module 3 errors 0301A0: FH BFH: The system is not standardized 8031D9: On-board voltage too low 804811: Supply undervoltage 8V5 Integrated automatic heating / air conditioning system 2 errors 801228: Power management: Reduction of fan power 801237: Rear window heating: Reduction of heating output due to power management |
12-12-2023, 07:41 PM | #5 |
Rep 1,751
Try to clear errors and check for errors right after the battery is fully charged. If you let the car sit (presumably) draining amps and then measure, it will throw too many error codes.
Are you driving the car after the battery full charge? Or just let the car sit and then measure? Trying to eliminate the alternator. If you did not drive and still drains in a day, then battery is bad or you have a significant short. Best would be, if you had a clamp on amp meter that can measure below 2-6 Amps. And check the amps with trunk open (close trunk lock latch manually to turn off trunk light). Watch amps during next 10-15 mins while car goes to sleep.
12-14-2023, 03:05 PM | #6 |
Rep 6
I've driven it all day once it is charged. Seems to be no issue with the alternator as the drain doesn't occur once I have it running for a bit. I checked batter level using Bimmerlink after driving it for two hours and it was at 99%. After having it parked and off withouth the alarm set for about 3 hours it was down to 88%
12-14-2023, 04:59 PM | #7 |
Rep 1,751
Looks like something is drawing power. You can go by the tedious and hit and miss method and start pulling fuses, or invest in a DC clamp on meter for about $30 up to $60. It should be able to measure below 10A with decent resolution.
Recommend the UNI-T UT210E Digital Handheld Clamp Multimet. 2A setting. https://lygte-info.dk/review/DMMUNI-TUT210E%20UK.html https://www.amazon.com/UNI-T-Digital...4C7I3ZAB0&th=1 https://www.ebay.com/itm/28537906212...caAhBGEALw_wcB EDIT: UT210E is better than UT203+.
12-19-2023, 07:30 AM | #8 |
Rep 6
Never done this type of troubleshooting, so help me understand the process. My understanding is I'm clamping onto the + batter lead and reading meter. Pull a fuse, check for a drop. Once I know where the drop was on the fuse, then I look deeper into what all is on that fuse and go from there, right?
12-19-2023, 08:02 AM | #9 |
Rep 1,751
You can clamp it on either the positive or the negative, doesn’t matter. Make sure you set the clamp on meter to DC and not AC. Also, I would set it at 20A or higher at first because tha car will draw 10-12A normally before going to sleep. Zero the meter after you initially clamped it on.
Before you even start anything, when you pop the trunk open, push the locking latch in with a screwdriver so the trunk light goes off. That way you can keep the trunk open and monitor the amp meter visually. Lock the car with the remote and move the FOB out of range. Observe the amp meter for the next 15-20 minutes. When/if the amps drop below 2A you can switch the meter to the 2A DC! scale and zero again. But if you have a large drain you will probably not see it go below 2A. With the amp meter on the battery, before locking the car, it will read probably between 10 to 12 A. After locking it, it should slowly drop down to 4 to 6 amp in about five minutes or less, and then down to one or 2 A under 10 minutes, and then drop below one amp eventually down to between 20 and 80 mA During this time, you should listen to any sounds or noises coming from the engine that would indicate something is still running. .
12-19-2023, 09:09 AM | #10 |
Rep 40
Open the doors & trunk hood. Lock it with screw driver then press lock key with remote.
Let it sleep for 1 hour don't bring car key near once car goes sleep. Take a look on all fuses & relays with thermal camera, or try to find out heated fuses with electric thermometer. little cheaper then thermal camera |
12-19-2023, 11:33 AM | #11 | |
Rep 6
