12-18-2023, 10:55 PM | #1 |
Rep 567
Turbo upgrade time. DIY swap help
Just took delivery of my Dynamic Autowerx V2.5+ GEN 1 B58 FLOW MAX. Got the installation kit and the turbo additive so should be set. I have a dorch s25 to install and get running before I start the turbo install too.
It's not a daily so I can take my time but I'm slightly hesitant to do the job myself because it's the most complex project I'll have done on my f36. Seeing from people who've swapped out their turbos what pitfalls and problems I might encounter. Any bolts a real problem to get to or easy to shear off. Any fluid hoses that are difficult to properly seat? Any stuff you would have done differently? Share your first hand tips and snags and put my mind at ease please!! |
12-19-2023, 07:13 AM | #2 |
Rep 856
The lines can be kinda hard to pry out, and a ton of coolant will come out. Like way more than you'd think, gallons. That line is how to drain the block now, there's no longer a drain plug. The factory manual uses a special tool to hold the exhaust manifold together and avoid damage to the flex points in the manifold. I guess just be careful with the manifold and try not to have it flex. Hold it by the center scroll not the manifold fingers.
B58 _gran_coupe_650.00 |
12-19-2023, 09:20 AM | #3 | |
Rep 567
Checked my plugs last night and they are good still |
B50AteYourRide70.00 |
12-19-2023, 03:58 PM | #4 |
Rep 684
Kern417 on youtube has a diy vid. Just get these silicon plugs from Amazon and plug the oil and coolant ports on the block to prevent it from draining.
https://www.amazon.com/High-Temp-Sil...s%2C158&sr=8-3 |
12-19-2023, 05:48 PM | #5 | |
Rep 567
12-20-2023, 07:39 PM | #7 | |
Rep 21
12-20-2023, 07:55 PM | #8 | |
Rep 567
12-30-2023, 01:54 AM | #9 |
Rep 567
I've been chipping away at this. 20 minutes here and there. Been waiting for some heat wrap for my downpipe but it should be here tomorrow so I'll get it monted and fired up.
I have used the liqui moly additive in the pil port on the turbo. Is this in place of dry priming the engine (pulling injector connectors and cranking) or in addition to priming? I have drained the engine oil and will refill when the lines are connected. Trying to avoid any damage before I get going |
12-30-2023, 12:29 PM | #10 |
Rep 338
almost there , get your tuner ready to flash a base map ^^ .. you can run on ots , but i wouldnt be flooring it everywhere lol .. i would go for a nice 50 miles drive to break in turbo
2018 340i - MHD CUSTOM TUNE, PURE850, DORCH STG2.5,MHD-FLEX-FUEL, M-PERF LSD, XHP Stg 2, CSF Heat Exchanger, M-Perf EXHAUST Mid Pipe BACK, Ross Racing Oil Catch Can, Evo Race Work Downpipe, PURE Inlet, DINAN Intake, VRSF Chargepipe
2011 335is - SOLD Last edited by nosam1g; 12-30-2023 at 02:58 PM.. |
12-30-2023, 12:38 PM | #11 | |
Rep 970
12-30-2023, 03:33 PM | #12 | |
Rep 567
I squirted the whole bottle of additive into the oil port and it found its way down through the oil drain. Turned the blades by hand. Feel like it was coated ok. Managed to get it in without removing the downpipe or the long coolant line that goes behind the block. The downpipe in place gave a nice reference that it was correctly positioned. Recommended. She's in and torqued in sequence. Managed to wrap the downpipe too. Only a small amount of blood lost. Did you even work on a bmw if you didnt bleed? |
WrxToBeamerGuy516.00 |
12-30-2023, 03:43 PM | #13 | |
Rep 970
12-30-2023, 11:07 PM | #14 |
Rep 567
Will prime the turbo and bleed coolant in the morning and then fire her up and check for leaks. All being well the heatshields and undertray can go back.
Stage 2+ flex at the moment but David Shoup will be handling the tune. I'll send the dme backup file then flash his basemap. Exciting times but I'm glad the swap is done. Was pretty frustrating at times. Maybe look at injectors and a diff next but I'll see how this feels. |
_ObiJon306.50 |
01-10-2024, 07:39 PM | #15 |
Rep 567
Quick update. I've been working with David Shoup and we've been feeling our way in to make sure everything is happy. So far so good. The turbo really wants to boost. Not turned up the heat yet but she's making about 26lb so far peak and very clean and linear. Hoping we can wrap this up by bimmerinvasion in February.
