01-20-2024, 02:06 PM | #1 |
Rep 1,150
So I was running the Ross racing kit, I have a one car garage and the wife was complaining about smell, so I removed it and sold it, I’m revisiting an idea I’ve seen in the old e36 days. Other platforms do it but looking for any disadvantages of this.
I would take my mid pipe, weld a bung in and run the dump tube to the exhaust. Thoughts on this? Bad idea? Good idea for my situation? Would this solve the smell issue? |
01-20-2024, 04:34 PM | #2 |
Rep 1,514
Ross kit does smell bad. I had one. Took it off and went back to stock style with the diaphragm. I always thought about running the hose to the intake so the turbo just draws it in.
01-20-2024, 04:44 PM | #3 |
Rep 1,150
That would be a good idea as well, just wasn’t sure how much vacuum would be pulled from the intake, vs the exhaust scavenge effect. Hmmm
01-20-2024, 06:24 PM | #4 |
Rep 1,514
I had that kit for 6 months and didn’t even get 1 drop of oil out of the drain. I think the stock pcv is fine as is. It’s worth carrying a extra diaphragm in your trunk and swapping it out when needed or doing it once a year as a preventative maintenance.
01-20-2024, 08:55 PM | #5 |
Rep 340
ross is perfect , if only the top portion can be capped , no hose. mine fills up a 1/4 a year
2018 340i - MHD CUSTOM TUNE, PURE850, DORCH STG2.5,MHD-FLEX-FUEL, M-PERF LSD, XHP Stg 2, CSF Heat Exchanger, M-Perf EXHAUST Mid Pipe BACK, Ross Racing Oil Catch Can, Evo Race Work Downpipe, PURE Inlet, DINAN Intake, VRSF Chargepipe
2011 335is - SOLD |
01-20-2024, 10:51 PM | #6 |
Rep 1,150
01-21-2024, 02:31 AM | #7 |
Rep 590
It’s been done before, definitely old school and something you don’t see often.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
01-21-2024, 06:51 AM | #8 |
Rep 6
I just started using the Ross Racing VTA kit. Install was relatively easy. It is true, the stench is noticeable from the inside especially during cold weather. However, I already have a catless DP so the smell does not completely bother me
01-21-2024, 11:22 AM | #9 |
Rep 1,150
01-21-2024, 11:24 AM | #10 | |
Rep 1,150
Personally I don’t care but I can’t deal with her complaining every weekend about this stuff anymore. |
01-21-2024, 12:31 PM | #11 |
Rep 340
u cant route it to the front passenger (so it smells on passenger side) , it doesnt have to go over the engine and below.
2011 335is - SOLD |
01-21-2024, 12:54 PM | #12 | |
Rep 1,150
Really just trying to keep it undetectable to the wife so I can have the benefits and not the smell. I think routing to exhaust will still produce smell given the exhaust system isn’t going to be hot enough to burn it off completely but thinking if it’s a significant reduction and redirected out through exhaust I may be ok. I think running it anywhere into the intake will pull way too much vacuum for it to be what I want. So this seems very limited to the exhaust routing. |
01-21-2024, 10:36 PM | #13 |
Rep 2,112
How about the PCV delete solution from VTTO (vargas turbo)? (okay, i know, nm the drama with the owner of VTTO for the moment...) Vargas solution caps the top at the low side (with PCV delete, eliminates the failure point with diaphragm). Catches the high side (with OCC). And has VTA with check valve at the oil cap. This seem like a good balance between "catching and recirculating" and "stopping" through VTA.
I too am running catless AA DP, and not want to go 2x the stench with bunch of VTA tubes, not to mention not doing service tech any favor with the VTA fumes coming right at the face while working on the car with engine on. Thoughts? |
ocdx30.00 |
01-21-2024, 11:44 PM | #14 | |
Rep 340
2011 335is - SOLD |
