01-21-2024, 07:55 PM | #1 |
Rep 83
DME Not working
2017 340i B58 BM3 multi map tune. I had a water leak and had to disconnect the battery for a few days, had to move the connectors and DME to get to the repair, shut the trunk. I couldn't get into the trunk open without power, had to use a battery charger to open trunk to reconnect battery. When I turn the key on and push the start button, it won't crank over, nothing. With the ignition on the car goes through suspension and other codes like when I flash the car, but the codes don't go away, it keeps cycling.
When I hook up the BM3 through iPhone, I get "clearing historic codes," but at the bottom it says "Check connectivity, there was an issue recognizing DME". The codes never clear. If I try to flash a map, it won't flash. I am wondering if I cooked the DME by using a charger or if I need to do something else to get it running again. When I run diagnostics, it acts like it is checking for codes but goes on for 5 minutes and nothing pulls up, it just keeps searching. Any help appreciated |
01-21-2024, 09:13 PM | #2 |
Rep 559
Are you sure you connected the DME properly? I don’t think you could have damaged the DME with a proper charger.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, Fabspeed Catted Downpipe, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
01-22-2024, 09:30 AM | #3 |
Rep 83
01-22-2024, 10:31 AM | #4 |
Rep 1,514
You can’t get the DME wires wrong. They are dummy proof from my understanding and go into one slot only. Double check the pins on the DME to make sure none of them got bent. I’m not sure if the F30 has any fuses in relates to the DME or any sort of modules that get powered up during a key cycle, but start checking some fuses.
01-22-2024, 11:12 AM | #5 |
Rep 194,473
It sounds like a connection problem rather than DME damage.
Double-check the pins and ensure they are connected all the way and none of them are damaged.
01-22-2024, 08:19 PM | #7 |
Rep 546
Had the same thing when I did Dinan DME unlock. One of the connectors was not pressed in all the way. All sorts of codes, no cranking and etc. The plugs can only be guaranteed 100% connected when starting from the back going to the front because of the lock lever at the front of each plug (disconnect starting from front).
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
01-23-2024, 09:11 AM | #8 | |
Rep 83
