03-10-2024, 12:02 PM | #1 |
Rep 499
ACC DSC + ICM High (5DF retrofit)
Up for sale is an ACC DSC Module and corresponding ICM High for all F3x cars 2014 and up, but also will fit most 2013. BMW changed their production in late 2012 to this "MK100" version. You can readily tell which DSC Module your car has by popping the hood and undoing three 10mm nuts on the driver side cowl. If you have an MK100 DSC on your car this module is directly swappable without any modification to the brake lines or wiring harness (though it would be needed to be coded to your vehicle). I was originally going to install these on my vehicle but I ended up finding a "black top" DSC Module which fits my 2012 with less effort. Please verify the ICM compatibility with your vehicle using realOEM (for some reason realOEM doesn't have the correct part numbers for DSC modules). These parts are being sold as a bundle and will need coding to your vehicle once installed. There are numerous resources available about completing the ACC / 5DF retrofit, though I will do my best to answer any questions. Price includes shipping within the USA and payment via Paypal Goods & Services, though international shipping isn't out of the question. If you happen to be in the New England area I am happy to meet within an hour or so of Boston for local pick up. I am open to offers but feel these items are competitively priced already. Thanks. DSC: ICM:
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo Last edited by rlesko; 03-11-2024 at 07:34 AM.. |
03-17-2024, 08:22 AM | #2 |
Rep 499
Bump!
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
04-02-2024, 06:28 PM | #3 |
Rep 499
Bump. Feel free to reach out about the retrofit in general and other parts needed, etc.
04-21-2024, 08:19 PM | #4 |
Rep 499
Bump, same as above. Price reduced.
05-10-2024, 11:25 AM | #6 |
Rep 499
Not quite. You still need a radar module which is mounted in front bumper. These are readily available less than $300 on eBay, salvage websites, etc. That is the one part shared across other F chassis.
Then, mounting hardware for the radar slightly differs whether you have M Sport vs regular trims. Wiring from Radar module to ICM would also need to be fashioned (4 wires), as well as 4 new wheel speed sensors (strangely enough, this part is shared with F8x, so some cheap versions available)
05-15-2024, 10:44 AM | #8 | |
Rep 499
https://www.realoem.com/bmw/enUS/sho...diagId=66_0299 This is just for random model/production year F30, just to show you the part.
