03-31-2024, 12:03 PM | #1 |
Rep 2
BMW F30 and Bimmercode
Hi everyone,
Last year I have used Bimmercode to activate the mirrors to close automatically when I lock the car. The issue is that now I don’t want this anymore, and I have lost the backup of the coding. I dont have the option anymore to disable it from BimmerCode. Any ideas on how I can disable this again? I have the App purchased and i’m using iOS device Thanks! |
03-31-2024, 12:45 PM | #2 |
Rep 414
Google has almost everything. Or use the search function here.....
https://f30.bimmerpost.com/forums/sh....php?t=1844177 |
03-31-2024, 03:44 PM | #4 |
Rep 2
@GreenF30N26
Thank you my friend. I've searched on Google, I posted even on local groups to find a solution but no-one was able to help me. @Billfitz I had only the option "Active" without anything else, but now it's solved. |
Billfitz8299.50 |
04-03-2024, 07:00 PM | #5 | |
Rep 7,584
The one has two coding parameters and the other only has one. IF you coded the convenience close for ACTIVE…and you don’t want that anymore…simply recode and select NOT ACTIVE. But it appears from the post above that the OP figured it out enough to be satisfied.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-04-2024, 01:56 PM | #6 |
Rep 16,189
There are cases where Bimmercode doesn't show the option for active or not active, just active. But if it's checked active and you click on that the check will go away, and that makes it inactive.
04-05-2024, 08:47 AM | #7 |
Rep 7,584
excellent follow up and explanation for the singular coding parameter
04-21-2024, 03:13 PM | #8 |
Rep 65
Hello Everyone apparently you need to update kombi and I-level to get the proper logos on BimmerCode. When adding the M performance, I get the M550d instead.Are you able to walk me through it and explain for me how to do it and what I need please? Look forward to hearing back. Thanks. 2018 Bmw 330i xdrive F30
