BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Stutter when light acceleration
      10-30-2024, 02:45 PM   #1
ConnorGerrard
Drives: BMW 318d 2013, BMW 435D 2015
Hello All
I have a 2015 435D with around 75k miles on the clock. No mods and drive in eco to and from work so I don’t rip the piss with the car.
I have noticed now for the past few days that sometimes when accelerating at lower gears and revs, that the car stutters/jitters when trying to pick up speed - again cruising in comfort or eco, slight push down on the accelerator and it starts to go and then stutters and then gets to it.
I tested this at high speeds and fast acceleration - I haven’t witnessed anything odd, all clicking together fine
I have seen people talk about this a lot with petrol engine and they recommend spark plugs and coil packs… which I don’t have, so could this be the glow plugs?
I have also seen someone mention transmission fluid change resolving the issue as well as other things here and there.
I do not believe it’s the gear box either.
No code reader has been done yet.
Any help or advice appreciated
Thanks in advance
      10-31-2024, 05:32 AM   #2
jjjccc
Drives: bmw f30 335i sedan
usually its bad fuel. or injectors clogged.or intake ports need cleaning thoroughly. if air is on, compressor could be goin out or sensor/pressure switch that is connected to the condenser,evaporator hose.
