| 11-01-2024, 04:11 AM | #1 |
Rep 1
Issues after flashing back to stock
I recently had my 435i in the shop to put the stock catalytic converter on and I also replaced ofhg, drive belt with tensioner, and cylinder head cooling hose. I also flashed from stage 2 to stock with bm3. And I have fbo with upgraded pure 500 turbo. After driving the car stock I’m getting a whole bunch of codes with drivetrain malfunction. Here’s all the codes:
MAP: Stock Tune CODES: 120308-boost pressure control,plausibility; pressure too low. 190F08-tank ventilation system, Malfunction (I’ve had this on the car for a few months now) 118002- Mixture Control: Mixture too rich 20AD09- Engine cooling system, Additional cooling pump speed outside of tolerance 1C3002- Engine Oil pressure sensor, electrical: Short circuit to ground Then there’s 2 other codes that bm3 says are inactive: 11CF30- Mixture control: Group Error 108932-intake air temperature sensor: Group Error. Any ideas? I’ve heard that running a stock tune with upgraded turbo can be bad for the turbo so should I at least flash it to stage 1? |
| 02-17-2026, 06:40 PM | #2 |
Rep 20
Getting the same codes: "11CF30" and "118001" (fuel air too lean). Car is MHD stage 2 with supporting mods, pump 91, 90k miles. Car drives normal, idle as it should, should also point out that I made the switch from E20 back to pump not too long ago, still running stock HPFP and LPFP.
was wondering what was your solution? any leads for me? cheers! Last edited by dmoneyn55; 02-17-2026 at 06:45 PM.. |
| Bookmarks |
