BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Cheap power supply for coding
      04-16-2026, 05:46 PM   #1
bennysbimmers
Drives: F30 330D
I’m getting my I drive updated for car play and need a charging solution.
Takes about 1.5 hours apparently and I need a cheap solution to keep it charged.
I remember reading a post on here, about making a power supply but can’t seem to find its
Any suggestions? The coding only costs 150 and I don’t wanna spend another 150 on a charger if I can help it
      04-16-2026, 08:47 PM   #2
thatgarrett
thatgarrett's Avatar
Drives: 2012 335i Sport
2012 BMW 335i  [7.68]
Absolute cheapest with a bit of risk- use a running car and jumper cables- I did a full istep update and had no issues but YMMV. I use a $120 RV power supply for all my coding and ISTA things now. There was some guy that used old server power supplies wired together but thay wouldn’t have been that much cheaper than the power supply I got and a heck of a lot more work.
      04-17-2026, 03:35 AM   #3
bennysbimmers
Drives: F30 330D
Thanks mate, most of the power supplies I see recommended aren’t available here in the UK
Which one do you use?
      04-17-2026, 04:44 AM   #4
bishbosh
Drives: F30 335d
2014 BMW 335d  [0.00]
That was my post from a few years ago: https://f30.bimmerpost.com/forums/sh....php?t=1628967
if I've helped - an Appreciate would be, er, very appreciated!
      04-17-2026, 05:45 AM   #5
bennysbimmers
Drives: F30 330D
Think that was the one I’ve seen
Might just have to connect another running car with jump leads, but I don’t think my gf will want her 26 plate idling for 2 hours 😆
      04-17-2026, 08:24 AM   #6
thatgarrett
This is the kind of thing I use, I have a slightly up-rated model since I was working on the valvetronic system, but this would probably be fine for coding.
https://www.amazon.co.uk/Maureen-Pow.../dp/B0DXTTLP6C
If you’re handy the DIY above will work just as fine too, just depends how cheap you can get rh components
      04-17-2026, 09:32 AM   #7
I've seen folk use their CTEK trickle charger and also the likes of Noco boost packs etc
      04-17-2026, 05:39 PM   #8
johnung
johnung's Avatar
I had a crazy flash problem a few years ago. I bought several chargers, even a very expensive heavy duty shop model. All of them should have worked but only one model from Stanley had very steady current to complete a long flash. Returned the others.
I’ve been using this Stanley (below) for years now. Great for flashing and battery charging. Kies Motorsports also did a video on this model a few years ago.
https://a.co/d/01bNLFdz
      04-18-2026, 03:36 AM   #9
Mick.86uk
Drives: 2015 F30 340i
If you are only flashing the HU and have climate control and headlights switched off you would be ok with this 20A 13.6v power supply.
Not sure how reliable it is though.
https://towntools.co.uk/products/rin...CABEgJpOPD_BwE
2015 F30 340i 18" 405M | MPPSK | Eibach Pros | MHD Stage 2
danb19793639.50
      04-18-2026, 05:48 AM   #10
E36 wire harness
It could always be worse
E36 wire harness's Avatar
752
Drives: E53 X5 6mt, F30 340ix 6mt, E36
I had a really nice Schumacher unit and it fell off the table and broke. So I had to buy another one and didn't want to spend another bunch of money this time. After a ton of research I ended up on this thing:
https://www.amazon.com/dp/B00F8MC43Q...ding=UTF8&th=1
It's worked really well. For trickle charging and maintaining during flashing I'm pretty sure that is the best bang for the buck out there. I've already spent the time looking. Factory manual says you need 70 amps, not 20. I don't know about 70 but I've definitely seen it pull 35 during flashing.
      04-18-2026, 08:43 AM   #11
Mick.86uk
https://www.amazon.com/dp/B00F8MC43Q/ref=twister_B0FRML1RSX?_encoding=UTF8&th=1
For the istep full software update where the climate control turns on automatically and other equipment is active then you would need 70A power supply.
For a HU only flash with everything else off 20A would be ok.
      04-19-2026, 03:46 AM   #12
Stainy
Drives: 435d Xdrive
i did the server psu mod years ago and still have it somewhere. I think it gives out a steady 60ish amps at 13.4 or thereabouts. In any case it's tuneable for less voltage/more amps (or vice versa). If I can find it, you're welcome to borrow it for the return postage - but I've a horrible feeling I "leant" it to someone and it hasn't come back. Let me know if you want me to look
      04-20-2026, 10:14 AM   #13
DThr33
DThr33's Avatar
762
Drives: F80 M3
you definitely shouldn't order one on amazon and return it once the coding's done, that's unethical and definitely not what i did when i needed one.
