BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
BMW Performance Big Brake Kit!! Fits E92 335???
02-07-2009, 02:26 PM | #1 |
Rep 59
Hi guys,
just wondering if anyone has this brake kit fitted on a E92 335... http://shop.speedreligion.net/bmw-pe...ear-1361-p.asp They are selling it at quite attractive price |
02-07-2009, 03:48 PM | #3 |
Rep 59
what?? smaller...I thought "Performance BIG brake kit" would be "bigger"...more brake power and so on..weird!!
Does anyone have any personal experiences about this kit?? |
02-07-2009, 05:49 PM | #4 | |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
The usual "BBK" suspects (Brembo, Stoptech, etc.) start at 355mm and go up from there. If you just want it for looks, then it should be fine. If you are looking for upgraded performance, it might work better than the stock brakes, but probably not significantly. Just buy the 6 line SS kit from ECS tuning, replace the fluid with something like Motul RBF600 and get some better pads, and I'd bet the stock discs and calipers would work better than the BMW "performance" kit. The cost would be significantly less to.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
02-07-2009, 08:08 PM | #5 |
Rep 59
Thank you Scollins a lot for detailed technical info!
I was thinking like 50% performance 50% looks..but since they are smaller, though with more pistons, I might have to think this over once more. |
02-07-2009, 10:50 PM | #6 | |
137
Rep 2,372
At the very least, they won't perform worse than your current brakes, but they not perform significantly better in comparison to the money they cost. The advantage is that they are BMW, so the dealer should give you less hassle about them, they aren't as expensive as other kits and they do look pretty good. But if you notice in my sig, I've got the STaSIS/Alcon kit for the front. I'm not running a rear upgrade (just yet), although when the front kit goes on, the mid and rear brake lines will get switched over to SS. My signature is a little premature though, as I've got the kit.........sitting in boxes in my garage! Haven't had time yet to get them installed...
Scott
02-09-2009, 01:21 PM | #7 |
Rep 336
Also rear dics aren't drilled/slotted so it won't look as nice in back as in front.
Where can we buy drilled dics (I wan't just the looks) for 335i will M3 dics fit, with original calipers etc.? |
