BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Blaupunkt THA 555 PnP
08-24-2009, 09:53 AM | #1 |
Rep 1,432
Is THA-555 PnP & SWS subs and upgraded individual series speakers still the best way to do an easy and good upgrade for the poor European basic audio? The amp is discontinued by many shops. I wonder if there are other alternatives or should I go and buy one from a vendor that still carry those?
08-24-2009, 10:41 AM | #2 | |
Rep 13,013
Note, to use a G6600 you will need to create a custom wire to RCA conversion cable out of the Blaupunkt PnP to interconnect with the G6600 RCA inputs: The G6600 accepts high level signals up to 11V peak; the OEM HU in the Stereo system puts out 8V peak (15W peak at 4 ohms) so this should work as a direct connection as the Blaupunkt amp. Use pin 13 in the back of the OEM HU as your remote turn on signal for the amp, it should be present in the Blaupunkt PnP harness. The RCA cable used in the photos is the JL Audio 2-channel twisted RCA cable in a 25ft length cut in the middle to create (2) 12.5ft, 4-channel RCA outputs out of the OEM HU speaker wire outputs and spliced into the existing OEM connector: http://www.shopatron.com/product/par...r=91699/1451.0 That's enough length to reach all the way to the trunk. This amp, a pair of SWS-8 and the Individual Audio front speakers (rears are optional) will give you excellent sound in a tight budget with a slightly above average of installation effort. |
12-14-2009, 10:23 PM | #3 |
Redline Addict
Rep 783
Could you help me understand a little better what's going on in the setup above?
YOu have a custom harness that plugs into the OEM HU. Then you're routing the two rca cables to the trunk to plug into the amp. Why are there only 4 rca channels, yet 6 inputs on the amp? Are you running a wire for the remote turn on from the harness up front back to the amp as well? Then you can simply swap the speaker output from the OEM amp into the new amp? Would you need some kind of processor to make it sound good? |
05-23-2013, 08:14 AM | #5 | |
Rep 5
Parts
Hi Technic, Can you advise on where to get the pins and box connector to make the custom RCA cable that plugs into the harness please. |
05-23-2013, 09:58 AM | #6 |
Rep 13,013
